I have a MII kit on my 51 chevy coupe, With Conversion brackets to use the mustang spindles with camaro calipers. My problem is The rotors are 9 inch and the brackets are for 11 inch, So can i cut the bracket down and plate each side? I have 14 inch rims and dont really wanna go to much larger..
you need either granada rotors if your gona run 4 1/2 wheel pattern, or early 80 rotors for a monte carlo i think it is if your running gm 4 3/4 wheel pattern . the original m2 rotors are 9 inch. if they gave you the gm caliper adapter brakets there made to run with 11 inch rotors . you can still run14 inch wheels with 11 inch rotors
