Hello, Is it okay to replace a single lifter, or should I replace them all? My gut is telling me to replace them all, but I'm looking for some input from those that have dealt with this in the past. I went through the lifters this weekend, deep clean and all that and found one that has to go. 1955 235 block. TIA Jorge
2 points. 1. Can you even buy individual lifters? I have never seen them come an quantities less than a full set. 2. If one failed due to fatigue (millions of load cycles over it's life span), the others probably aren't far behind and have a reduced number of cycles left until they fail as well.
Well, yea. You can replace just one. Fred the frugal farmer has done it many times. It's an answer but maybe not the best answer. But what's the issue with the one? Are there scuffs or a divot in the face? What I'm wondering is what does the cam lobe look like?
When I worked at new car dealerships, replacing one lifter was the norm. However, we are talking about new, low mileage vehicles. If I was going to replace just one, I'd make sure the others were in tip top shape. Pay particular attention to the lifter face where it meets the cam. The face should be slightly convex, not flat.
When you pull the side plate, take each lifter out, inspect, & replace. The condition of the cam lobes will tell you all you need to know. A used 235 that doesn't need the cam reground or replaced would be unusual ....
Echo of some earlier posts: The question isn't the lifter, it is the cam, I'd try it since it's cheap but only if the cam lobe is perfect. And that is very unlikely if the lifter face shows wear.
OK so the deep clean.... basically a good clean, try to get all the grime out and what not. As to what was wrong with the one bad one, it has a Crack on the top around the base of the "cup", and the whole top section is loose.
Replacing one lifter is usually OK...but if you replace all of them, or replace the one cracked one and get the rest reground, get the cam reground also, or find a new one. Rock Auto lists new ones individually, they're pricey....Delta regrinds cams and refaces lifters, that might be the way to go for the rest, if they need it.
I may have found the culprit....mayyyyybe. after looking over the cam, well that one seems to be a goner.
