SOLD Panel: Stewart Warner chrome and engine turned gauge panel. The gauge panel is beautiful and is 9" long x 3" tall. I bought the panel as a NOS in its original box and packaging. I recently engine turned the panel to give it an incredibly beautiful look. Water Temp Gauge Size: 2 1/16" Stewart Warner Water Temp Gauge. Gauge is a full sweep and reads from 0 - 165 degrees. The gauge works great and gives an accurate reading. The capillary line is 72" long and is in great condition. Has a light bulb port in the rear of the gauge with a light bulb installed. AMPS Gauge Size: 2 1/16" Stewart Warner AMPS Gauge 0-60-0. Gauge is tested and works properly. There is a very small area of clouding near the 60 and the left side, see photos. Has a light bulb port in the rear of the gauge and there is a light bulb installed. Oil Pressure Gauge Size: 2 1/16" Stewart Warner Oil Pressure Gauge. 0 - 80 PSI. The gauge works properly. It has a light bulb port on the rear of the gauge with a light bulb installed. See photos and ask questions. Small blemish by the 60
