Complete open drive halibrand 201 quickchange. Case has been repaired well at some point. All new bearings, rear cover, 28 spline slip in axles double drilled bolt pattern with screw in studs. Big ford ends welded on axle tubes and brand new rear brake drum assemblies. Complete rearend built for model a. Will include a pair of spring hanger brackets and 1 set of gears. 3500 Just south of Austin and North of SAN Antonio
