I have what I believe is a W-10 Westinghouse Coke machine. Surface rust good solid shape. It has dollies under it but a couple are stuck so I built the dolly you see here to move it around. I plugged it in, the water pump runs but the compressor is stuck. This would make a cool couch. It is missing two panels on the back but if you made a couch you could move the two upper ones down and would be perfect. I have the bottle opener and the box that catches the caps just not shown in the pics. It would be pretty fancy all painted up. Thanks for looking. Lippy
