I bought this car in Wichita, Kansas and it is an excellent car to start a project. There is surface rust but overall the frame and all body parts are very solid. I failed to tighten a strap after loading it in my trailer and it rolled back in the trailer, damaging the right rear quarter panel. I have a good used front split bench seat and rear seat springs only. I have all the sheet metal, some glass and a ton of stainless steel exterior trim. The best part is the front of the frame was removed and a 70's Trans Am subframe was grafted onto the original frame at the firewall. This subframe gives you, complete front steer setup, room for that V-8, disc brakes and 5 x 4 3/4 bolt pattern. The front clip is very solid and can be set on the car. It is complete with inner fenders, hood and fenders. The steering column is from the Trans Am. My plans were to install a Cadillac 500 V-8 and make it a highway cruiser. I bought the motor with 60k miles and the matching turbo 400. We got the motor running but it will not be included with the car. I need to sell the motor & trans separate. I do not have a title but I do have the vin and firewall plate for the car. Title can be obtained through the internet. [GALLERY=][/GALLERY]
