sold it please remove
Discussion in 'Cars For Sale' started by playingoldcars, Dec 17, 2015.
  1. playingoldcars
    playingoldcars
    City: Oak Forest
    State: Illinois
    Price: $6,500
    1965 C-10 Longbed Pickup
    • Custom Cab with all the trim
    • Original paint with lots of patina (surface rust)
    • "283" 3 on the tree
    • Very straight, solid
    • Runs & drives very well
    • 6 lug rally wheels with brand new tires (WW) with receipts from Discount Tire; I have a set of stock wheels if that's what you want.
    • Chrome bumpers and grill
    • Inner fenders perfect; Rear wheel tubs perfect
    • Diamond plate bed floor over original wood; In the pictures the floor can be seen in tact but is rotted around the outside.
    • All lights and turn signals work as they should. The speedometer and odometer
      currently reading 90,XXX, also work as does the heat and defrost.
    • I think the roof clearance lights might be original or dealer options which would be a very rare option. They also work but are missing one lens.
    • The undercarriage and frame are really solid as can be seen in the pictures.
    • The floor supports, body mounts, and inner rockers are very solid and appear to be original.
    • The cab floors have a couple of very small non-threatening holes as does the outer rocker on the driver's side which can also be seen in the pics.
    • The truck has the helper leafs for overload which were also an option and are in addition to the coil springs on all four corners.
    • The windshield is OK for driving but does have a stain which appears to be inside the lamination.
    • The seal around the glass is dry rotted and cracked and needs to be replaced.
    • The door glass is good and rolls up and down as it should.
    • The door locks also work as they should and can be locked and unlocked with the original keys.
    • This truck would be an excellent candidate for a full restoration but has such great potential for a patinaed Old Skool.
    • Please check out the YouTubes BELOW to see the truck in running, driving action.
    • It sounds really mellow with dual exhaust with twin chrome tips coming out each side.
    • Illinois title in my name.
    • $6,500 Oak Forest, IL 60452
    • https://youtu.be/_2jxDgRpVz4
      https://youtu.be/TUBTMBbEvMg
      https://youtu.be/tS2v5noxFrM
  2. playingoldcars
    playingoldcars
  3. playingoldcars
    playingoldcars
    will do trades too
  4. playingoldcars
    playingoldcars
    bttt gonna start to fill some holes and do some primer soon
  5. playingoldcars
    playingoldcars
  6. playingoldcars
    playingoldcars
