Halibrand 101 *SOLD* Here is a complete Halibrand 101 Quick Change. Ready to run after some assembly. It is in excellent condition. No repairs. It comes with ring/pinion and two different shafts so you can run it with the in-and-out control or without. Bearings are included for both, but to use the solid shaft without in-and-out control you will need to have a spacer machined for the bearing to fit. It comes with Model A axles and housings that are also in excellent shape. New bearings and bearing races are installed. The Culver City rear cover is not included. It comes with the Torrence City cover with new bearings. It comes with a set of Winters gears 23/25. Local Pickup only
