Cool old Hotrod that runs and drives great. All steel body with a working cowl vent and tip out chromed windshield frame, stock style top insert, doors open and shut nice. All windows go up and down like they should. Steel grill shell and steel hood. paint isn't the best and it has a big primer spot on the back, but still looks cool. The chassis is an original 32 frame that has been boxed and has stock front and rear frame horns. '57 9" rear end on a cross spring and ladder bars, with 3:25 gears and a locker. The front axle is a drilled and chromed 4" dropped I beam with hair-pins and vega steering. Has Drum brakes all around that work good. The interior is a mix of vintage low back buckets in front and a stock-ish bench in back, and more recently done door panels and side panels all in black vinyl. It has old Stewart Warner gauges / panel , and a GM column with shifter. The engine is a Small Block Chevy of unknown displacement backed by a T350 transmission. The wiring is re-done with an aftermarket harness. This is a neat old hot rod, and is ready to drive, It isn't perfect.......but it also isn't sixty grand !! $31,000 Sorry, but no checks, trades, or delivery. I am in Moro Oregon, which is 2 hours east of Portland.
