SOLD 1932 Ford Roadster Project - Brookville Body on Original Chassis w/Title Great start on a traditional 32 roadster. New Brookville body on an original 1932 Ford frame with old and new parts. Frame is a nice straight original from an old hot rod. The k-member is original to the frame and the front and rear crossmembers were replaced with good originals that are bolted in. There is one old repair above the front crossmember on driver side. The front suspension is a 1932 heavy axle with a 4” drop by Okie Joe. It has round back spindles with the steering arms bent to clear the un-split 32 wishbone. The rear end is a 1948 Ford and includes torque tube, drive shaft, and radius rods. The 48 springs were ground to fit the 32 crossmember. The torque tube and driveshaft need to be shortened and it will be ready for a flat head and 3 speed trans. Wheels are Early Ford 16x4” and 16x4-1/2” w/ new Firestone 4.50 and 7.50 tires. Body is new from Brookville and comes with cowl vent and stock style door hinges and door handles Firewall and hood are originals with old paint and wear that could be restored or left as is. Grill shell, insert and gas tank are new from Vintique. Comes with current and correct title for 1932 Ford roadster matching #’s on the frame. Always happy to work with international buyers and we can wrap the body for protection during transportation. If you intend to buy additional parts you can ship them to my shop and I will secure them inside the car for shipping. Can deliver to GNRS or Turlock in January. $22,000 Will consider partial trades for Early Ford projects, bodies or parts. Call 865-755-7019 with any questions.
