So lost need guidence...
Discussion in 'The Hokey Ass Message Board' started by Chopped&Dropped, May 7, 2008.
  1. Chopped&Dropped
    Chopped&Dropped
    from Salt City
    I want to convert my generator to an alternator. I have read a couple different ways of doing so but I want to know what is the best way to go. Should I use 1 wire alternator or 3 wire. And if I use a three wire how do I wire it up? Which one is better I dont want to create any more issues.
  2. I would use an internally regulated 1 wire alternator. GM is the easy one, but some guys have done it with others.
  3. wvenfield
    wvenfield
    My 54 Chevy had a 1 wire alternator. Easy to hook up and I had zero problems with it.
  4. beatcad
    beatcad
    what year/make car are ya workin' on?
    if it's a 55 or later GM it could be as easy as lookin' for(or makin') diferent brackets.
    is it an early 50s car, and ya also want to go from 6 to 12 volt?
    than that's another story, but still very do-able.
    you can find an older external reg alt and bolt it in place of the gen and wire it the same way.......or you could get an internal reg. alt. and bypass/remove the voltage regulator on the firewall or rad. support depending on the car ya got.
    i could maybe give ya more info, but i gotta know what car yer workin' on and what ya really wanna acheive.
  5. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    I converted my 6v Plymouth to a 12v and used the one wire GM alternator. I have always had the three wires in the past on mt different cars but found the one wire so easy I will never go back.
  6. Old Gold
    Old Gold
    Heres a schematic for a three wire. For one wire you eliminate the wire that energizes the dash light. The three wire is energized by the dash light, the one wire is designed to energize at a set RPM. Hope that helps. (this is what I did for my Packard. Eliminate "carb switch" if your starts off key.)
  7. jdj9410
    jdj9410
    from Paris TX
    Speedway sells an alternator in a generator housing by Powermaster. One for flatties and one for GM's. Little pricey at about 400 but pretty good if going for authentic.
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    If you are running a Ford flathead. Buy a 1960-63 rebuilt 12 volt. The housings are exactlty the same as the 6 volt units. You may have to trim the front cover for clearance.
  9. Nothing wrong with a three wire and a regulator.
    I've been using rebuilt Pinto alternators and regulators from NAPA.
    Last time I bought them, $34. for the alternator and $12. for the regulator.
    The alternator is relativey small physically speaking and has enough charging for most any hot rod.
    Get Skip Readio's book on "Electrical Systems."
    Published by Tex Smith.
    It's available at Amazon and is the best DIY book out there.
