Technical So let's discuss Stromberg 97's and associated parts
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Mar 25, 2020.
  1. Roothawg
    Roothawg
    First, let me preface this with, I am not a carb guy. Wanna talk Hilborn fuel injection, I'm all about that.
    So, I have a little 29 Model A roadster with a 265 and a 3x2 with 3 Strombergs. The previous owner only had the center carb hooked up. I found the linkage under the seat for the other 2. So basically it's a 2 barrel.
    The problem: It pukes all over itself occasionally. Like out of the top, around the accelerator pump rod etc. The car has a really small 12V elec. pump and one of the Mr Gasket regulators. I figure the float is hanging and allowing it to overfill.
    The questions:
    1. Who sells the best/most complete overhaul kit for a 97?
    2. Who sells the most accurate low pressure regulator 5 lbs. and under?
    I would like to get this thing running right, but I only wanna do it once.
    Thanks,
    Root
  2. walter
    walter
    I use ONLY a vein type pump. If its a pulsating pump it will push past the needle and seat. I also set the fuel regulator at 2-3 PSI
    Roothawg and lumpy 63 like this.
  3. lumpy 63
    lumpy 63
    Holley 12-804 is the regulator we use for low pressure applications Root.
    Roothawg likes this.
  4. Bandit Billy
    Bandit Billy
    Holley 12-804 regulator. 1-4 psi. Personally, I avoid the round dial types.
    mad mikey and Roothawg like this.
  5. alchemy
    alchemy
    Buy one of the Holley regulators. They come in a higher pressure version and one that regulates from 1 to 4 pounds. And buy a low pressure gauge from Dickster here in the HAMB classifieds. Then set them to 2 pounds MAX.
    And, any Stromberg parts or service you need can be obtained from our own Uncle Max. He's the absolute best.
  6. manyolcars
    manyolcars
    Dont buy the round Holley. Its just a restrictor and my engine was starving at 90
  7. Roothawg
    Roothawg
    90? Dang son......slow down and smell the roses.
    blowby likes this.
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    Dickster here in the Hamb will provide you good rebuild parts.
    Residual electric pump pressure after the engine is shut off will cause Stromberg leakage also. A solution would be to install a separate switch for the pump and turn it off before the ignition.
  9. Roothawg
    Roothawg
    It does it going down the road. I can always tell. It smells like raw fuel and then I can look over the windshield and watch it geyser. The round Mr. Gasket regulator worked great for a while.
    Petejoe likes this.
  10. Blue One
    Blue One
    from Alberta
    mad mikey likes this.
  11. Roothawg
    Roothawg
  12. alchemy
    alchemy
    Blue, that's a sanitary looking installation. Is that regulator aluminum? If it is I think I'd be inclined to scratch the Edmunds logo into it and give it a buffing. Help hide the newness.
  13. Blue One
    Blue One
    from Alberta
    Thanks, I welded a mount for it to the edge of the crank case draft hole block off plate.
    It is aluminum and I had considered taking it apart and blasting it for black paint but never got there.
    I may in the future but I think it looks okay down low on the side of the engine.
    And it works great at 1.5 psi.
  14. alchemy
    alchemy
    Oh, they are spendy though. I could buy six of the good Holley regulators for that price.
  15. Blue One
    Blue One
    from Alberta
    I’ve heard that they aren’t so good anymore.
  16. blowby
    blowby
    from Nicasio Ca
    I just run the stock flathead pump, works great.
    On another note, what can I use to get a nice looking finish, without resorting to paint.
  17. Roothawg
    Roothawg
    I can't on a SBC. I mean I guess I could, but it may take some ciphering. :cool:
  18. Roothawg
    Roothawg
    I did some troubleshooting tonight. When it would start loading up, I would turn the pump off to see if it would clean up and it did. So the carb may just need a new pressure regulator first, then worry about the overhaul later.
    Petejoe likes this.
  19. 51box
    51box
    from MA
    I run one of these Malpassi units on my car with 97’s. It is a low pressure regulator and filter all in one. 0F54641B-A549-418E-B6E1-9D59B91A3DBA.png
  20. 51box
    51box
    from MA
    Anything stromberg related shoot uncle max an email, he is great to deal with.
  21. Pretty Y-block!
    Blue One likes this.
