Snapped bolts and stuck plugs fix.
Discussion in 'The Hokey Ass Message Board' started by johnod, Nov 19, 2012.
  1. johnod
    johnod
    Today at work, stripping an OT engine, snapped of 5 small allen bolts holding a cover on, which were threaded into the water jacket, and that was after heating them first.
    Left about 1/4 inch stub proud of the block.
    Remembered something i think i read here,
    WAX
    So I heated them up pressed candle to them, grabbed on with the vise grips and out they came easy as pie.
    Next were some stuck galley plugs,thought I'd try it again, heated and applied wax, they practically fell out.
    I reccomend this highly to anyone.
    And to whoever mentioned the wax here in the first place, a big thanks.
  2. FE exhaust bolts....wax is the way
  3. i appreciate that you took the time to post some advice based on your experience.
    not just another "how do i....." thread.
  4. woodypecker
    woodypecker
    Allen bolts also snap from a side load from long allen wrench. Whenever possible use a T handle to torque evenly.
  5. junk yard kid
    junk yard kid
    I use paraffin wax from the canning section of the grocery store. Its a great trick.
  6. f1 fred
    f1 fred
    from mn
    Thanks for the testimonial. Now, will my brain recall this when needed? :)
  7. partsdawg
    partsdawg
    from Minnesota
    I know I never do;)
  8. saltflats
    saltflats
    from Missouri
    Well put the candles in your tool box then just try to remember if that are for broken bolts or for when you forget to pay the electric bill.
  9. beeswax candle in the tool box work great because the beeswax has a wicking effect so it draws into threads in any position.
  10. 340HilbornDuster
    340HilbornDuster
    Good tips!....
    ...."gick up en Liljeholmens!"..Swedish Hot Rodders get it!
  11. zep058
    zep058
    Any tips on valve cover bolts that snapped level with the block? I have one that I hardly torqued and *snap*! The next sound was me throwing the socket wrench across the garage in anger haha!
  12. Wax on,,wax off,,:D HRP
    <iframe width="640" height="480" src="http://www.youtube.com/embed/fULNUr0rvEc?rel=0" frameborder="0" allowfullscreen></iframe>
  13. Left hand drill bit. Drill small and move up. Many times just the drilling will back it out. If not get to near the thread minor diam and the the remaining threads should nearly fall out. Use a pick or similar to get them out. If you do it centered good, the threads will stay good in the head.
  14. 270dodge
    270dodge
    from Ohio
    Yes sir thats what it's about. You remembered it and passed it on, congratulations.
  15. pitman
    pitman
    Has anyone tried this for stainless steel bolts, in aluminum?
    Tenacious is an understatement with these 'fits'.
  16. pitman
    pitman
  17. Bert Kollar
    Bert Kollar
    Not to brag, but I posted about wax on 6/30/10 and I am glad somebody took the advice, if it was my post. I learned about wax from an old time shop in 1965 and have used it on many engines with 100% success. Works better than anything else.
  18. This cat beat you by five years.
    http://www.jalopyjournal.com/forum/showthread.php?t=61288
  19. oj
    oj
    Beeswax for me, they sell little sticks of them in most hardware stores, they usually have a basket of them up near the cash register.
  20. vntgtrk
    vntgtrk
    Gotta be a song in there somewherz............................
    I'm an old f@rt and ain't heard of this one. Thanx OP
  21. Big Bad Dad
    Big Bad Dad
    Please enlighten me on this process. I am soon facing the manifolds on my f 100. :confused:
