Customs Smoothed and peaked '58 Chevy bumper build EDIT:It has been chromed!
Discussion in 'The Hokey Ass Message Board' started by Imperial Kustom, Feb 20, 2019.
  1. Imperial Kustom
    Imperial Kustom
    I thought some of you guys might get a kick out of this front bumper for a 1958 Chevrolet sedan delivery I restyled a while back.
    I removed the center "yoke" and scratch built the new center. It was metalfinished to a relatively high degree in preparation for chrome plating.
    FB_IMG_1550693292161.jpg FB_IMG_1550693265252.jpg FB_IMG_1550693280796.jpg FB_IMG_1550693393780.jpg FB_IMG_1550693244447.jpg FB_IMG_1550693254426.jpg
  2. Imperial Kustom
    Imperial Kustom
    FB_IMG_1550693149910.jpg FB_IMG_1550693178171.jpg FB_IMG_1550693187849.jpg FB_IMG_1550693128407.jpg FB_IMG_1550693202328.jpg FB_IMG_1550693227548.jpg FB_IMG_1550693217929.jpg FB_IMG_1550693165011.jpg Here are a few build pictures. The first are some wooden profile templates taken from the original bumper profile. A steel profile wad then shaped and used as a control for the dimensions of the the new parts. I also built a super ugly jig but it holds all the parts in alignment and true.
  3. Imperial Kustom
    Imperial Kustom
    A final couple pictures that were taken while metal finishing by hand. Hammers, dollies, files, sanding blocks and a DA sander were used. FB_IMG_1550693353822.jpg FB_IMG_1550693336509.jpg
    Stogy, tb33anda3rd, rockable and 8 others like this.
  4. BJR
    BJR
    Wow that's looks great. Thanks for sharing the pictures and info.
    Stogy likes this.
  5. texasred
    texasred
    from Houston
    Nice work, instead of bolting on something from a different car which in some case's is much easier to do
  6. Imperial Kustom
    Imperial Kustom
    Well, the owner of this bumper finally got around to having it chromed and got it on the car. This is such a good look for these '58 Chevys. The chrome looks fantastic.
    Here is a picture he sent to me of it mounted. I will go to take more and get them up as soon as I can.
  7. Rckt98
    Rckt98
    Man that is a lot of work but a great result.
    I know I shouldn't ask but how many hours would you have in it?
  8. Imperial Kustom
    Imperial Kustom
    I started with a stock 3 piece bumper that was in need of recroming anyway. I removed the center "yoke", trimmed the ends of the bumper and handbuilt about 2 1/2 feet of the middle. All of the bodywork was done in lead. Took about 35 hours.
    This also included building the jig, the templates and any R&D.
    Stogy likes this.
  9. larry k
    larry k
    I'll bet chip goose has hard on after seeing that ??? Really nice work !
  10. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    That is some amazing work! Can't hide bad work under chrome, it don't stick to bondo!
    kidcampbell71, Just Gary and ClayMart like this.
  11. To my eyes, stock '58 Chevys always look too busy to me. GM styling went to a whole lot of trouble to make them look like a similar vintage Cadillac but not too much like the Cadillac. When a '58 Chevy gets customized, all too often it seemed to get even more gimcracks and geegaws and other "kustom" tricks added to it that made things even busier looking and it usually makes matters worse. Looking at a lot of them made my eyes hurt.
    But it looks like your customer, fortunately, took the higher ground in his approach by choosing to eliminate some of this extra 'busy-ness". I'm curious to see if he took this approach with the rest of the car.
    Either way it appears that you did right by your customer, and you did right by yourself.
    Stogy likes this.
  12. Imperial Kustom
    Imperial Kustom
    Agreed. This modification changed the whole dynamic of the front of the car. It is so much more cohesive and streamlined now. The grille looks so much better uninterupted by the bumper and every line is now parallel and working together.
  13. X-cpe
    X-cpe
    Great results when vision and skills mesh. What gauge steel did you use and how did you make the bends and curves?
  14. 49ratfink
    49ratfink
    wow. what a difference. looks good.
  15. Imperial Kustom
    Imperial Kustom
    I used 12 gauge steel and formed it in the brake a little at a time.
    FB_IMG_1555790418275.jpg FB_IMG_1555790389068.jpg FB_IMG_1555790432761.jpg FB_IMG_1555790362635.jpg FB_IMG_1555790583824.jpg
    j hansen, Stogy and rockable like this.
  16. This sort of mod used to be more common... Nice to see somebody reviving it!
  17. 56premiere
    56premiere
    I was parked next to it in Emmett today. It really looks nice , truly a great job.
  18. Imperial Kustom
    Imperial Kustom
    Another shot sent from the owner. This simple modification cleans up the front of these cars immensely. I can't get enough of looking at this.
  19. 40StudeDude
    40StudeDude
    And MOST people wouldn't even notice it's been modified it's that good...nice job...
    R-
    ClayMart likes this.
  20. Imperial Kustom
    Imperial Kustom
    I finally got around to seeing this bumper in person and taking a few photographs. 20190427_091905.jpg 20190427_091846.jpg 20190427_091836.jpg 20190427_091829.jpg
  21. Smokeybear
    Smokeybear
    The bumper and grille look great but the hood alignment on the passenger side is kicking up my OCD. :D
  22. Imperial Kustom
    Imperial Kustom
    Me too. He is going to bring it by the shop to get the hood aligned.
    BigO and Stogy like this.
  23. Nice work. Was the same thing also done to the rear bumper?
    I'd like to see it with the factory grill and parking lights.
  24. Chavezk21
    Chavezk21
    That looks amazing. I would also love to see that with stock grill and parking lamps.
  25. Stogy
    Stogy
    I know very little about chroming...I didn't know lead could be chromed...
    Great job @Imperial Kustom you have every reason to be proud of that...
  26. That's some really nice work, thanks for the update. BigO
  27. Lead is the main ingredient in solder, and that's plated all the time.
    Stogy likes this.
  28. 41rodderz
    41rodderz
    from Oregon
    Yes siree Bob. That took it from a 4 to a 12
    :). Nice work and your customer must be tickled pink to have that fine bumper. Sets that grille off big time.
  29. Imperial Kustom
    Imperial Kustom
    Not yet, but it is in the plans. We are working out a couple different designs at the moment.
    Stogy likes this.
  30. 41rodderz
    41rodderz
    from Oregon
    Really like your avatar Mr. Kustom :cool:.
