Hot Rods Smoking
Discussion in 'The Hokey Ass Message Board' started by Alex Gillman, Jul 3, 2020.
  1. Alex Gillman
    Alex Gillman
    I just got my car running and as soon as I put the foot down it starts to bellow blue smoke, but still ran ok. I assumed it was a ring, but the #7 intake rocker had came off. Would this cause the excess smoke?
    Thanks,
    Alex Gillman
    Sent from my SM-G960U using The H.A.M.B. mobile app
  2. flatford39
    flatford39
    Isn't blue smoke oil consumption being burned off...meaning weak rings?? I am surprised it ran smoothly with an intake valve closed. What kind of engine?? V8 or straight flathead 8??
  3. Alex Gillman
    Alex Gillman
    It's a 79 Chevy 350
    I was surprised too. I will probably pull it and make sure
  4. I smoked a pack a day for over 45 years and quit four years ago. Oh engine smoke. If it is a shevrolit it is supposed to smoke.
    loudbang, VANDENPLAS and Texas Webb like this.
  5. greybeard360
    greybeard360
    Intake rocker coming off could cause it to draw oil up past the rings.
    King ford, bobss396, blowby and 3 others like this.
  6. squirrel
    I'll sell you a set of flathead 8 rocker arms cheap...
  7. Alex Gillman
    Alex Gillman
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    is this engine in your avatar Pontiac? just curious. yes, an intake rocker being off will and can make your car smoke. imagine all the vacuum created by the piston going down the cylinder without the intake valve open it is trying to draw from wherever it can like past the rings into the crankcase. make sense? put a rocker arm on it and see. good luck
    Desoto291Hemi, egads and flatford39 like this.
  9. squirrel
    Is it a fresh engine? or a used one?
    We can only guess...not enough info!
  10. spanners
    spanners
    Are they on the same shelf as the glider engines?
    King ford and hotrodjack33 like this.
  11. kevinrevin
    kevinrevin
    from East Texas
    Yep. Next to the Muffler Bearings and Blinker Fluid.:p
  12. Mr48chev
    If it is a fresh built or rering job the person who assembled it may have dipped the piston in oil to oil up the rings like I have done for the past 57 years, it gets a bit smokey at first but it burns off pretty quick.
    If it is an unknown quantity engine that you just picked up it could indeed be worn out to the point it is going to burn a lot of oil. Or the valve seals may be shot if the smoke clears up after a few minutes.
    Alex Gillman likes this.
  13. :p:p:p
    Ben
  14. Alex Gillman
    Alex Gillman
    Yes it is.
    I will give it a shot!
    Desoto291Hemi likes this.
  15. hotrodjack33
    hotrodjack33
    All this talk...I need a cigar:D
  16. Ericnova72
    Ericnova72
    One shelf over from the VW Beetle water pumps...:p
    Intake rocker off so intake valve not opening is going to cause it to draw a hell of a lot of oil up past the rings during the intake stroke
  17. King ford
    King ford
    from 08302
    Weellll, looks like it's old enough to smoke....
