Between the extreme cold and straight into mid 90`s temps it's hard to want to work in home shop after working in the heat all day. But I have gotten a little farther along! As with my luck I've had to build everything. Bought a universal 4 link kit and not one bracket fit like I wanted so I had to build every bracket. But the rear end is square to the frame, measures 1/16" length to the front horns and 1/16" side to side so the rear should track perfect. Built the cross member out .100 1_1/2" tube. Put the offset so I could get the bolts in and out. Now I have a rolling frame! Now I've started building quarter elliptical springs. Hopefully in a couple weeks the spring setup will be done. So here are a few pics of the rear, just need finishing of the welds.
