Has anyone else had this happen? Turned on computer today H.A.M.B is very small on screen the only website that's small.Can someone please help a guy out?
If you have a mouse with a wheel on it hold ctrl down and turn the wheel it will increase or decrease the size of the screen. Depending on your browser you may also have three dots up in the right corner of the header which if you click on will open a menu and there should be a zoom tab that will allow you to adjust the screen size.
Press CTL and + at the same tie and it should increase the size,if that doesn't work see a doctor if the size last longer than 4 hours. HRP
It's not the size of the HAMB it's the size of the HAMB bone. Sent from my SAMSUNG-SM-G890A using The H.A.M.B. mobile app
If my .... lasted for four hours I wouldn't be seeing a doctor, I'd have several "visitors" maybe dressed like a doctor/s......
Pressing control and 0 zero at the same time will usually bring the screen size back to your standard viewing size in most cases.
