Auctions
Small Block V-8, V-6 and inline 6 Chevy Engine Parts
Discussion in 'Parts For Sale' started by enigma57, Oct 14, 2017.
  1. enigma57
    enigma57
    City: Houston
    State: TEXAS!
    Price: In Ad
    Having retired, it is time to inventory and put up for sale items remaining from past projects. All parts are new unless noted otherwise.
    If interested, please send PM. I am located NW of Houston, Texas.
    * Will ship smaller parts within lower 48 states...... Payment by US Postal Money Order or PayPal (gift to friend) accepted.
    * Larger and / or heavier parts to be picked up in person, cash on receipt or pre-payment by PayPal (gift to friend) accepted.
    All sales are final......
    $2,000 firm - New Edelbrock Victor Jr. heads for small block Chevy with full portwork by Mondello. New in box, never been bolted to an engine.
    Modified Offenhauser 4-carb intake port matched to heads included at no additional charge other than shipping. Intake is similar in layout to Man-A-Fre and is 95% completed.
    If interested, please send PM. I can send photos of heads and intake (zip files) via E-mail.
    I had Joe Mondello's Shop rework these 23 degree heads for a 427 stroker small block as an affordable alternative to 18 degree or 15 degree heads.
    I asked Mondello to port these heads so as to maximize flow at valve lifts below 0.550". I was looking for a flow rate for this engine of at least 300 cfm at that lift.
    The specs Mondello gave me are as follows......
    * Edelbrock Victor Jr. Aluminum Heads Fully Ported By Mondello Racing - 23 degree with standard valve spacing (no offset rockers required)
    * 65cc Combustion Chambers, polished
    * 2.08" intake X 1.60" exhaust valve sizes - Stainless Steel Pro-Flo with 5-angle valve job
    * Intake Ports - 2.35" High X 1.40" Wide = 3.25 sq. in. cross section at port opening (allowing for rounded corners) - Pushrod pinch point measures 2.80 sq. in.
    * Exhaust Ports - 1.65" High X 1.65" Wide = 2.68 sq. in. cross section at port opening (allowing for rounded corners)
    * Dual Valve Springs Set @ 140 lb. seat pressure / 340 lb. open / cryogenic stress relieved
    * P.C. Teflon Valve Guide Seals
    Flow @ 28 in. (no pipe)......
    lift cfm cfm
    LIFT - INTAKE - EXHAUST
    0.100" - 071.00 - 063.00
    0.200" - 145.00 - 113.00
    0.300" - 205.00 - 157.00
    0.400" - 260.00 - 190.00
    0.500" -306.00 - 205.00
    0.550" -313.00 - 211.00
    0.600" - 320.00 - 217.00
    Following portwork and machining, Mondello cryogenically treated these heads
    $180 - GM crossram intake base for 1st design GM 229 V-6 Bowtie racing heads. With very few mods to intake, this intake can be made to fit '85 - '94 4.3 litre V-6 production heads as well. Consists of base only - You will need make a top plate to fit the carburettor(s) you wish to run.
    $150 - Set of Paragon reproduction finned aluminum valve covers for late '59 - '66 Corvette 283 and 327 engines. New in box.
    $300 - Offenhauser #5253 dual quad 360 degree intake for small block Chevy (polished aluminum finish, very nice looking intake)
    $200 - 1961 - 1962 Corvette dual quad intake manifold for small block Chevy.
    $50 - Power Pack heads (bare cores for rebuilding) for '59 - '64 small block Chevy. These castings are #520 castings (best ones, for power pack heads) and need to be rebuilt with new valves and springs and cleaned up.
    $200 - GM cast iron marine single 4bbl intake for small block Chevy. No longer available from GM. This is the one the circle track guys use where a cast iron OEM intake is required by track rules. Similar in design to the early Z-28 aluminum high rise intake except marine intake is cast iron and will accept both Holley / Carter AFB square bore carbs and Q-jet / Carter Thermoquad spread bore carburettors.
    $50 - New heavy duty mechanical fuel pump for small block and big block Chevy. New in box, never been bolted to an engine.
    $150 - New GMPP HEI distributor for small block and big block Chevy. Recurved by Dave Ray. New in box, never been bolted to an engine.
    $100 - Crankshaft for 292 Chevy inline 6. This is the hard to find forged steel crank made only in USA for 1963 (and 1963 and 1964 for Canadian built 292 engines). All later year 292 cranks are cast nodular iron. Turned 0.010" - 0.010" .
    $25 - Bellhousing for 1976 Dodge Dart with 318, 340 or 360 engine. Has the large 5-1/8" register hole for A-833 4-speed overdrive transmission
    $100 each - Have 2 power rack and pinion steering units for 1993, 1994 Buick Front Wheel Drive cars. These are spec'd for the T-Type and police cars with quick steering and increased road feel. May fit other year Buick and Olds FWD cars, as well. As new, reconditioned by GM.
    Thanks for your interest,
    Harry
    1Nimrod, GlassThamesDoug and y'sguy like this.
  2. enigma57
    enigma57
    Offenhauser 3 carb intake and new 2-1/2" outlet exhaust manifold for 1963 - 1984 Chevy inline 6 have been sold. Other items listed above remain available.
    Thanks,
    Harry
  3. enigma57
    enigma57
    Weber 42 DCNF carburettors have been sold.
    Sanderson QP 1000 exhaust manifolds have been sold.
    Remainder of parts listed are available.
    HB
