Technical Small block harmonic balancer?
Discussion in 'The Hokey Ass Message Board' started by erock805, Dec 30, 2017.
  1. erock805
    erock805
  2. squirrel
    looks like a 327 or 307 damper? or maybe a 283? how about measuring the diameter....????
  3. Deuces
    Deuces
    from Michigan
    And thickness.....
  4. uncleandy 65
    uncleandy 65
    Hard to tell by the picture, but it looks to thin for a 350
  5. Deuces
    Deuces
    from Michigan
    That's what I was thinking.....
  6. larry k
    larry k
    265 or 283 ,to light for a 327 on up !
  7. 56sedandelivery
    56sedandelivery
    NOT a 265 or 283, those are riveted together, although some 283's use just a "hub" with NO elastomer or ring of any kind. So, 327 AND early 350. Do a Google search for "Images of SBC balancers" (I prefer to call them dampeners). Factory and aftermarket balancers/dampeners are displayed. The "High Performance" dampeners are usually larger, but we all know ANY of these dampeners can be swapped around that are neutral balanced, and the appropriate timing tag used. We use a lightened or lighter weight flywheel to allow engines to rev quicker, same with a dampener. I'm not sure how the larger dampeners came to be used, unless it's because of all the accessories driven off of them, and the torsional issues associated with those. But then again, I'm NOT an engineer by ANY means. To answer the OP question, "Is this a normal 350 balancer"; it is AND is't. Use it, I would. I am Butch/56sedandelivery.
    Truckdoctor Andy likes this.
  8. DDDenny
    Pull that center bolt out and take another photo.
  9. Deuces
    Deuces
    from Michigan
    I took another look at it and it looks like one for a 350... We just need a side shot photo of it to confirm...
  10. MAD MIKE
    MAD MIKE
    from 94577
    In relation to the keyway/spoke on the damper.
    If the outer ring has not slipped I *think* the timing notch is in the position for '70s SBCs.
    IIRC pre-'350' dampers had the timing notch in the 12 O'clock spot.
    80's SBCs used that funky timing tab mounted behind the waterpump with the notch ~45° before.
  11. TagMan
    TagMan
    Pull it off and check for casting numbers
  12. Should work on a 350, however the elastomer- rubber ring looks to be NOT in the best shape. Outer ring can slip, and or walk.
    Just Gary and badvolvo like this.
  13. Mike VV
    Mike VV
    from SoCal
    Standard performance 327 damper (harmonic damper), maybe even early low perf. 350.
    A balancer...balances things, a damper...dampens things (harmonics).
    These devices, dampen crankshaft harmonics. They don't balance...anything.
    Mike
    mad mikey likes this.
  14. squirrel
    that's for sure. I've given up on that pet peeve. Good to see someone is still after it
  15. The one for the 350 should be 6.75" in diameter. I got mine at Summit for around $65.
  16. badvolvo
    badvolvo
    Either way, looks like its time for a new one.
