Small Block Ford factory cam specs?
Discussion in 'The Hokey Ass Message Board' started by Untame, Jan 18, 2012.
  1. Untame
    Untame
    Does anyone have a link to camshaft speciications for factory Ford cams? In particular, I'm trying to find the int/ex duration, LSA, and intake centerline of a 1974 302 cam.
    Thanks!
    Untame
  2. George
    George
    Don't know, but on a '74 it's going to be pretty lame.
    JeffB2 and Deuces like this.
  3. Untame
    Untame
    Thanks, George. I'll plug "pretty lame" into my software and see what I get.
    Untame
    Beanscoot and Deuces like this.
  4. shinysideup
    shinysideup
    from ruskin, fl
    Search "who cares?" if that doesnt work for you.
    You get these kind of answers when you have no info at all and want specifics. Do you realise how many different cam profiles Ford made that year alone?
  5. Dapostman
    Dapostman
    I think I have them in an old Petersen's manual. I don't have it here, but I should be able to get it tomorrow.
  6. Untame
    Untame
    No, I don't realise how many different cam profiles Ford made that year alone. I'm all ears. Tell me where I can find a grind number on the cam. I've looked -- maybe it is under varnish somewhere.
    Thanks for helping. :)
    Untame
  7. Untame
    Untame
    That would be awesome! Thank you!
    Untame
    PS -- I'm surprised nobody has put a table/database online. Maybe it is because most guys just get an aftermarket cam rather than tuning their factory cam.
  8. fordor41
    fordor41
    I just went thru the same thing. Research the stock cam thru Autozone, advance auto etc, if you know what model it is for, like T-bird,mustang.
    If you find it listed, the specs. should be there.
  9. savannahDan
    savannahDan
    if you go to melling dot com, you can look up the specs for stock replacement cams.
    Melling # : SYB-25
    Part Description : Camshaft
    Opens : -22 BTC/12 BBC
    Closes : 26 ABC/-8 ATC
    Duration : 184/189
    Opens : 22 BTC/45 BBC
    Closes : 70 ABC/40 ATC
    Duration : 272/265
    CamLift : .230/.238
    Gross Valve Lift : .368/.380
    Center Line C/L : 114/104
    Rocker Arm Ratio : 1.6/1.6
    Valve Lash Clearance : HYD/HYD
    It also lists other cars and years that used the same cam, it was used from 65-76 for all the normal 302's.
  10. Relic Stew
    Relic Stew
    from Wisconsin
    This was in Pat Ganahl's Ford Performance book.
    It only goes to '72 as that was the year it was published. They changed the slot on the chain sprocket to retard the timing 4° in '72, but the cam didn't change.
  11. Dapostman
    Dapostman
    intake opens 16/20
    intake closes 70
    duration 266/270
    intake lobe lift .2303
    rocker ratio 1.6/1
    valve lift zero lash .368
    exhaust opens 44
    exhaust closes 20/24
    exhaust duration 244/248
    overlap 36/44
    exhaust lobe lift .2375
    valve lift zero lash .380
    auto/ manual
    per Petersen's
  12. Untame
    Untame
    Thanks, Guys! So if I put a Comp Cams Magnum double roller timing set on there I would be able to advance the cam back the 4 degrees that were lost to the smog era.
  13. George
    George
    Umm, lame is the answer that comes out!:p
    I was thinking that I've seen pics of the slot in the timing gear being moved instead of in the cam itself, so that it would be straight up or advanced depending on if you sat the new gear adv or on o.
  14. Untame
    Untame
    LOVE this resource! Thanks for the tip.
    However... the numbers are different from the scanned page in the post above. :\
  15. Untame
    Untame
    So I searched the part number C3AZ-6250-V and I get pages with differing "official" specifications. :confused:
    I'm pretty sure that is my part number because my cam is stamped "UA".
  16. Untame
    Untame
    So if I go with Pat Ganahl's numbers (most likely correct), then is it possible for me to discern the Intake Centerline and Lobe Separation Angle from these numbers?
    I come up with a Centerline of 117 and LSA of 141.
    <style type="text/css">p { margin-bottom: 0.08in; }</style> Camshaft &#8211; (part C3AZ-6250-V)
      • Intake Duration &#8211; 266
      • Intake Opens/Closes &#8211; 16 BTC / 70 ABC
      • Exhaust Duration &#8211; 244
      • Exhaust Opens/Closes &#8211; 44 BBC / 20 ATC
  17. Dapostman
    Dapostman
    I get an LSA of 109.5.
  18. Untame
    Untame
    Thanks -- I knew that 141 seemed outrageous.
  19. 6narow
    6narow
    Apologies if resurrecting an old thread angers anyone, I just ran the lift specs, with an extra .010 added to the lobes and it gives a significant change in lift (.368/.380 becomes .384/.397).
    I wonder how much that would change the duration @ .050?
  20. George
    George
    302 didn't start until '68, so it was for the 289. would run "smaller" in a 302 than in a 289.
  21. 6narow
    6narow
    I bet, seat-of-the-pants, you'd probably be hard pressed to tell the difference between a 289 and a 302, with both engines being in the same condition and state of tune.
  22. dumprat
    dumprat
    from b.c.
    I have a spec book for ford engines from53-70. It lists all the high performance specs.
