small block chevy oil leak
Discussion in 'The Hokey Ass Message Board' started by mysteryman, May 5, 2012.
  1. Abomb
    Abomb
    Try taking the cap and rotor off before you take the engine hoist to it....if there's a wiper motor, or some other component in the way, I'd remove that too....
  2. barcode
    barcode
    from fort knox
    no wiper motor in the way just the lip of hte firewall.
    86 s10 blazer with a 350 in it.
  3. Jedidiah
    Jedidiah
    from Ft Worth
    It looks like we have a funny boy. :D
  4. barcode
    barcode
    from fort knox
    very
  5. SBC only has a few things to leak back there, intake, valve covers and the off chance of a head gasket or a dist seal (the oil pressure unit would be more of a drivers side leak). Use a flashlight and a mirror.
  6. I would suggest you need new valve cover gaskets and seal them. HRP
  7. Jimbo17
    Jimbo17
    On my 350 I had changed an oil pan gasket and everything worked fine for the first day or two and then I started seeing oil on the rear of the motor.
    I thought I had just missed a bolt so I tightened the bolts again and within a day or so more oil on the rear of the motor.
    This time I started looking much closer at just what was going on.
    The brand New gasket kit which was kind of costly and was one of those blue thick gasket came with New bolts because of being thicker.
    The brand new bolts were bottoming out in the holes!!!
    I trip to a local hardware store for shorter bolts solved the problem with the oil pan leaking.
    Jimbo
  8. Mr48chev
    It might honestly be simpler to loosen the cab and core support bolts and raise the cab a bit to get the distributor out on that particular truck then try to slip the engine forward.
    If you read the manual for instructions for pulling the trans and transfer out of a S-10 4x step 1 is unbolt left side of cab and raise it 2 inches and put a block between the cab and the frame for clearance.
    But yes take the cap and rotor off as Abomb suggested. The valve covers will have to come off anyhow to get the intake off so check the gaskets close.
  9. old soul
    old soul
    from oswego NY
    Did you check the mass air flow sensor????
  10. n847
    n847
    Dear God let it end!
  11. deto
    deto
    2 quarts in 50 miles? Did you check to see if the drain plug is installed in the bottom of the pan?
