Hot Rods Small Block Chevy in 1932 Ford water pump clearance issues
Discussion in 'The Hokey Ass Message Board' started by wildwest, Oct 13, 2019.
  1. wildwest
    wildwest
    So, I had a chassis built by a reputable shop , looks great, all TIG welded, I was pretty happy with it when I picked it up. When I first went over the project with them, I asked specifically if it was possible to run a SBC in a 32 without cutting up the original firewall, and still have room for everything while running a radiator in the stock location, and a full hood. He said it would be tight , but yes doable. I took them my trans (Tremec TKO) and they said they didn't need the engine because they had a mock up block to use. Today I finally got the trans & engine married and stuck it in the chassis to find a pretty major water pump to Radiator clearance issue. I have a long water pump on it now, but even with a short, I don't see any way it would work, Even the electric ones are just as deep. Does anybody make a really short pump & pulleys ? what are my options ? I really don't want to have to grind off the pretty new engine & trans mounts and do that all over........ Plus, the Firewall clearance is perfect. Help !
    LOU WELLS likes this.
  2. Pete Eastwood
    Pete Eastwood
    from california
    I've done it , but it's tight.
    Definitely going to need a short pump & a fan with pitch to the rear only.
    Maybe a water pump riser would help too.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    X2 short water pump.
  4. wildwest
    wildwest
    It's hard to tell from the pictures, but after measuring, I don't think a short pump will be short enough.
  5. Bill Rinaldi
    Bill Rinaldi
    Put a short pump in, it's tight but it will fit. Depending on how low the engine sits, PeteE is correct, a riser pump may help center the fan. The electric fan and shroud that Walker radiator recommends is your best bet to keeping it cool but not necessarily HAMB correct. It will also fit. Think about a smaller than HEI distributer, the HEI PROBABLY wont fit, with out "nudging" the fire wall. Bill
  6. DDDenny
    When I had my roadster chassis built (friends shop) I had most everything except the hood, I asked where I might have clearance issues, he said the usual suspects, the radiator and the firewall, he suggested a one inch increase in front crossmember location and said just have Rootlieb built the hood one inch over stock length, glad I did as the Steve Long radiator was ordered with electric fan, not my idea but still glad he did.
    When I picked it up the motor mounts were just tacked in and I asked why, he said you will thank me, he was right, even with the extra one inch, a short water pump and small body distributor the motor mounts needed to be moved slightly.
    These cars are generally considered a "paint by numbers" build but there are so many variables component wise that a quarter inch can make all the difference.
  7. David Gersic
    David Gersic
    from DeKalb, IL
    An early Corvette short pump will gain you a little bit more room.
    Splitbudaba likes this.
  8. Pete & Jake's has the instructions on motor mount measurements that you need.
  9. wicarnut
    wicarnut
    Here's pics of mine, had alum short water pump, HEI distributor, electric fan, had to clearance plastic fan housing some for WP pulley, not really enough room for a fan and it would be at bottom of radiator using a small diameter fan blade. I Don't have a pic with better angle to show how tight it was. This setup cooled a premium gas Speed Shop HP crate 355 and cooled it well even in hot weather with A/C running, exception was if I had hood side panels on and in a traffic stalled out cruised situation it would get pretty warm, I would run without the side the panels if I knew I was going to be in that type of situation and it would stay at around 200 deg or less. HorsePower makers heat, the milder your engine, the less cooling issues IMO. I know this not a true HAMB solution, but most of the 32's I've ever looked at ran a similar setup, without the A/C on, it ran cool enough with side panels on. I had a 29 HighBoy Roadster without hood, side panels. A/C, it ran fine/cool with that small diameter mechanical fan at bottom of radiator, Walker radiator, again a HP 355, I was asked many times if that little fan worked ? pics in my album. I drove both of theses cars over 20K miles without any cooling problems. I hope this helps you and a side note, a few guys I know that tried the raised up WP deal were not happy with them took them off their engines, did not cool properly. Good Luck, Enjoy, Git R Dun
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Time to put grill shell on with radiator (there are thick ones and thin ones) with hood and side panels and go from there. A tape measure and imagination isn't enough.
  11. DDDenny
    And heavy ones!
    wicarnut likes this.
  12. You need a zips riser, you will need a Chevy 6 cylinder water pump and a good quality fan.
    The zip's moves the water pump up about 5" and it places the mechanical fan in the center of the radiator, you also gain room.
    I've used this on several '32 Fords.HRP
    LOU WELLS, j3harleys, Andy and 2 others like this.
  13. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    You have to mock it up, guessing does not apply....
    LOU WELLS, alchemy and Splitbudaba like this.
  14. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    short pump
  15. If you ordered it to fit and clear from a reputable shop I'd go back to them and ask exactly what parts were used for mock up so you could get the same exact pieces to run. If that don't get you the space you need why would you be the one to cut things up and start moving stuff around to make it fit? Isn't that the reason you pay someone to do the hard stuff for ya?
  16. DDDenny, how deep/thick is that fan at the motor?
  17. Country Joe
    Country Joe
  18. Blues4U
    Blues4U
    from So Cal
    Agreed. Maybe the shop should add a mock up water pump to their mock up block....
    WB69 likes this.
  19. Splitbudaba
    Splitbudaba
    2A8A2675-B55A-4E80-87BD-83E0C04DD4BC.jpeg 952E85E1-BA42-45A6-B2FF-738A8D9FF941.jpeg 9B839EE0-02AB-4EE2-9AF4-09FA0165E093.jpeg Short pump, no spacer and a 56 Chevy metal fan. Fits great! Being new at this I mounted the engine with the bottom of the block even with the frame rails, getting the fan more in the center of the radiator. Down side was the fact I had to fab up a floor tunnel. But it all worked out, the tunnel gave me a great place to mount my e brake handle.
  20. [​IMG]
    The firewall looks like it's been cut/modified. HRP
    j3harleys, Johnny Gee and lurker mick like this.
  21. wildwest
    wildwest
    I was playing with a plum-bob and tape last night, I'm going to find some cardboard to tape on the radiator and play with it, after I remove the pump. I plan on having to use an electric fan. I have the heavier Walker radiator.
  22. Rodders
    Rodders
    Needs a short water pump
  23. Splitbudaba
    Splitbudaba
    Just added the bump outs to accept the steel front mounts on each side. And yes it’s fiberglass! Oh yuk!
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Know that you blew up photo sure enough.
  25. 19Eddy30
    19Eddy30
    from VA
    with Zips you can , you have to play with fan size & your motor angle , when installing Rad & shell last to install, you will be 1/2-1 inch from Rad
    j3harleys and Just Gary like this.
  26. wildwest
    wildwest
    Well, I got a short Water pump today, and mocked it up with the center hood hinge piece, and it looks like it's going to fit (Barely !) Thanks for the help everyone ! Now I just need to figure out the best way to deal with having the lower radiator outlet on the drivers side, when the water pump outlet is on the passenger side..............
  27. Splitbudaba
    Splitbudaba
    I think I would look into a different radiator!!
    lothiandon1940 and WB69 like this.
  28. Your local radiator shop should be able to move the lower hose to the right side.
    Phil
  29. 19Eddy30
    19Eddy30
    from VA
    if you go with a zip it will move fan to center of rad , & move the bottom blade away from rad , you can run a bigger mechanical fan & gain more Clarence
    I run a zip on my big inch SB & turn over 6,000 rpm , No problems with the 6 cylinder pump, a easy fix to move bottom inlet , just leave driver side in & cap off. Walkers not cheap so I use a flatty style radiator now because I will be run different engine combos
  30. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Just to add about mechanical fans. A stock GM type will have pitch forward of fan hub. To pick up another inch a flex fan will get you more room. If that style is an option you'll accept.
    clem likes this.
