Technical Small block chevy ID again
Discussion in 'The Hokey Ass Message Board' started by porkshop, Sep 2, 2018.
  1. porkshop
    porkshop
    from Clovis Ca
    Block casting number 3914678. I come up with 1968 302,327 or 350. Pad stamp number, V0620HT I come up with Flint engine plant, June 20th.and the HT comes up 65 thru 67 Vette 327 350 horse or 69 350 full size. Other pad stamp number is 18S423700 and i cant find no info there. The engine has pop up pistons. Just trying to figure out what it is. I have included pictures. Thanks in advance..... 20180902_142915.jpg 20180902_142713.jpg 20180902_142710.jpg
    Deuces likes this.
  2. porkshop
    porkshop
    from Clovis Ca
    Just looking for your thoughts as what I have found contradicts itself....
    Deuces likes this.
  3. Deuces
    Deuces
    Let's see those pistons please....
    Thanks!....:cool:
  4. AngleDrive
    AngleDrive
    from Florida
    18S423700
    Serial number of car it came out of
    Deuces likes this.
  5. porkshop
    porkshop
    from Clovis Ca
    I dont own it yet. I did not think to get pictures of them. If i go back I am going to measure bore and check stroke. Will get pictures then.
    Deuces likes this.
  6. porkshop
    porkshop
    from Clovis Ca
    yes, but I have not found a way to decode it, that makes any sense....
    Deuces likes this.
  7. Its a 1969 350 255hp manual trans.
    327,350,302 are all 4" bore blocks so they all could use that casting number
    67 back are small journal and no 350s so the HT code is for the 69 350
    Sent from my VS996 using The H.A.M.B. mobile app
    Deuces likes this.
  8. But swapped cranks and rebuilds in the past could be anything now
    Deuces likes this.
  9. squirrel
    18S.... means 1968 Vette (S means built in St Louis).
    congrats, you actually have a Vette motor!
  10. Black Panther
    Black Panther
    from SoCal
    An actual Corvette motor! HT for 1968 is a 327 350 hp...L79. That casting number block ending in 678 was only used in 1968. The vin number starting as 18S...the 1 is for Chevrolet...the 8 is for 1968..and the S is for St. Louis MO...where they built Corvettes. The 423700 number is the sequential build of the car...for Corvettes in 1968 they started numbering with 400000...so this engine came out of the 23,700th Corvette built in 1968...its a fairly late motor. Went back and looked at the pic of the engine code..V0620HT...V for Flint Michigan where the engine was assembled...0620..June 20th...so it is a late motor..buy it!
    Deuces, coolhandponcho54 and squirrel like this.
  11. Black Panther
    Black Panther
    from SoCal
    No 1969 engines used this casting number block...its 1968 only..
    Deuces and catdad49 like this.
  12. Black Panther
    Black Panther
    from SoCal
    From the pics looks like it doesn't have camel hump heads? It should have
    ..casting number ending 291...
    Deuces likes this.
  13. AngleDrive
    AngleDrive
    from Florida
    the 1 would be big 2 door sedan or impala custom, the 8 would be year 1968, the S is built in St Louis.
    the last six are actual serial sequence of car.
    Deuces likes this.
  14. Left overs
    Deuces likes this.
  15. Penetrator
    Penetrator
    from SK CAN
    I've searched and can't find this information. I get the date codes, casting numbers, etc., etc., but nothing for a partial VIN past the first three characters. Care to share?
    Deuces likes this.
  16. porkshop
    porkshop
    from Clovis Ca
    I dont know if the heads on it belong to it. They were just on with a couple bolts. It has a anson bell housing, missing the lower cover. Has what apears to be a Saginaw 4 speed with a modified vette shifter. Now the big question? What is it worth? It is out of a old drag car and had a hilborn injection on it at one time.....
    Deuces likes this.
  17. DDDenny
    Affirmative
    I have a pair of NOS "291" heads, the box said 1968 Corvette initial stock, the last year of true camel hump castings.
    Deuces likes this.
  18. AngleDrive
    AngleDrive
    from Florida
    I stand corrected it is a vette motor not big car.
    Deuces likes this.
  19. squirrel
    partial VIN....find a place that decodes complete VINs, then realize that the partial VIN is
    Carline (1 = Chevrolet car, 2 = Pontiac, C =Chevy Truck, etc)
    Year (8 = 1968 or 1978, B = 1981, etc)
    Asembly Plant (F =Flint, Z = Fremont, J =Janesville, etc)
  20. All SBCs came from vettes
    OLSKOOL57 likes this.
  21. squirrel
    no they didn't.
    Deuces and Truckdoctor Andy like this.
  22. Only if you are selling them......
  23. Black Panther
    Black Panther
    from SoCal
    Penetrator....I've gleaned most of my knowledge from Alan Colvins "Chevrolet by the Numbers" series of books. I assume you mean you cant find info on the sequential numbering? It's in those books.
  24. Black Panther
    Black Panther
    from SoCal
    I agree...it kind of bugs me when people call the 1969 1970, 186, 492 heads, camel humps.
    Deuces and Old wolf like this.
  25. AngleDrive
    AngleDrive
    from Florida
    VIN Range 194378S400001 – 194378S428566
    1 (First Digit) Make/Manufacturer. 1 – Chevrolet
    9 (Second Digit) Model series. 9 – Corvette
    4 (Third Digit) Engine type. 4 – V8 Engine (all types)
    37 (Fourth and Fifth Digits) 37- Corvette Coupe / 67 – Corvette Convertible
    8 (Sixth Digit) Model Year. 8 – 1968
    S (Seventh Digit) Vehicle Assembly Location. S – St. Louis, Missouri
    4XXXXX (Seventh thru Twelfth Digits) Plant Sequence Numbers.
    The last six digits begin at 400001 and run thru 428566, accounting for all 28,566 Corvette Coupes/Convertibles built in 1968. Each Vehicle Identification Number (VIN) is unique to an individual car.
    Deuces likes this.
  26. And all FE engines are 390s unless I own it. Then it’s a 360
  27. Penetrator
    Penetrator
    from SK CAN
    Yes, the sequential numbers. (Thanks, I'll look for his books.)
    Deuces likes this.
  28. Black Panther
    Black Panther
    from SoCal
    He has a book for 1955-59, 1960-64, 1965-69 ( I dog eared that one) and 1970-75. He also has a Corvette by the numbers that goes all the way back to 1955 till 1982. All sorts of info in those books. Casting numbers..how to read dates..vin number breakdowns per years..etc.
    Deuces likes this.
  29. lumpy 63
    lumpy 63
    NO!! Only if they have corvette valve covers on em! Don't you know anything???
    OLSKOOL57 and Deuces like this.
  30. Royalshifter
    Royalshifter
    Moderator
    Camel humps?....they look like boobs to me, but then again everything looks like boobs to me. By the way I have the engine and it ran in the Gold Rush drag sedan B Gas from 1966-1969 out of San Jose, it never could keep the front wheels on the ground
    kidcampbell71, Deuces and loudbang like this.
