Having retired, it is time to inventory and put up for sale items remaining from past projects. All parts are new unless noted otherwise. If interested, please send PM. I am located NW of Houston, Texas. Will ship smaller parts and split shipping cost within lower 48 states...... Payment by US Postal Money Order accepted. Larger parts to be picked up in person, cash on receipt...... No checks, MOs nor credit cards. All sales are final...... New heads and exhaust manifolds for small block Chevy and crossram intake base for V-6 Chevy...... $2,800 - Victor Jr. heads with full portwork by Mondello, intake ports matched to 1209 gasket size, 65cc chambers, 2.08" /1.60" valves. Intake side flows 306 cfm @ 0.525" lift per Mondello. $1,350 - GMPP Fast Burn aluminum heads, 210cc intake ports, 62cc chambers, lightweight 2.0" / 1.55" LT4 valves $180 - Edelbrock Performer RPM intake for Vortec & Fast Burn heads (Removed from new GMPP crate engine. Bolted on engine but never run.) $180 - GM crossram intake base for 1st design GM 229 V-6 Bowtie racing heads. With very few mods to intake, this intake can be made to fit '85 - '94 4.3 litre V-6 production heads as well. Consists of base only - You will need make a top plate to fit the carburettor(s) you wish to run. $180 - Sanderson QP1000 cast iron exhaust manifolds. Special ordered with both sides having outlet centered. Note: These are both passenger side manifolds. They tuck in very close to the block and on the drivers side, there is a clearance issue with one of the raised bosses cast into 1958 and later blocks for side engine mounts. As such, either the boss must be ground about 1/4" for clearance and '55 - '57 front mounts used...... Or spacers similar to those used to adapt Stahl headers may be fitted between drivers side head and manifold to gain additional clearance so side engine mounts may be used. New roller rocker set...... $215 - GMPP self-guiding roller rocker arms (set of 16 special ordered with 8 having 1.6 ratio and 8 having 1.5 ratio) - Note: Self-guiding rockers can be used with hydraulic lifters only Used intakes...... $300 - Offenhauser #5253 dual quad 360 degree intake for small block Chevy (polished aluminum finish, very nice looking intake) $180 - 1974 Aston Martin Series-3 Isolated Runner intake original to 5.3 litre Lagonda V-8. Only 967 such Series-3 Aston Martin V-8 cars were produced. Mounts (4) Weber 42 DCNF carbs (not included) $150 - Early 1980s Maserati 4.9 litre V-8 Isolated Runner intake. Mounts (4) Weber 42 DCNF carbs (not included) New transmissions, bellhousings, flywheels, clutches...... $3,000 - New T-56 Borg Warner 6-speed production trans, OEM for '93 - '95 Camaro or Firebird with 305 or 350 engine. Price includes new GM bellhousing, new GM flywheel, new GM '94 Camaro hydraulic master and slave cylinder and new Center Force (pull type) clutch upgrade for this transmission. Best regards and thanks for looking through the listing, Harry
Bowtie block and rotating assembly to build 427 stroker small block have been sold. Thanks, raven! HB
350 Chevy L31 short block is no longer for sale. My son will be using this engine in his Camaro. Remainder of parts listed are available for sale. Thanks, Harry
Aftermarket T-56 transmission has been sold. New OEM '93 - '95 (Camaro/Firebird) production T-56 6-speed transmission complete with new GM bellhousing, GM flywheel for SBC with 1-piece rear main seal, new CenterForce pull type clutch upgrade, new GM hydraulic clutch master cylinder and slave cylinder setup and other parts listed remain available for sale...... Thanks for your interest, Harry
