Small Alternator?
Discussion in 'The Hokey Ass Message Board' started by Ragtop, Feb 18, 2013.
  1. Ragtop
    Ragtop
    Anyone know of a very small alternator that could be used on a HotRod and tucked in tight where it's not too visable? I'd prefer one with a built in regulator and maybe a one wire deal. My buddy has one on his Willys that he got from a circle track guy but nobody knows what it was made for. Some small off shore car I think. A typical Chevy alternator is too big for my application. Thanx!
  2. Try looking at fork lift alternators.Clark for example
  3. tfeverfred
    tfeverfred
    Grab the Nippondenso engineering ID#'s (100211-606, 100211-635 for this one) and head for your favorite auto parts store. They should be able to c/ref that number(s) and supply you with a relatively inexpensive rebuilt.
    Or 1987 Suzuki Samuri. In stock at Autozone. Kinda pricy at 99 bucks (lifetime warranty), but they are teeny weenie, 60 amps and come with a V-belt pulley.
  4. saltflats
    saltflats
    from Missouri
    We just got one for an O/T MGB that is crome that fits a toyota fork lift thinks in on the engine in my avatar
  5. 48FordFanatic
    48FordFanatic
    from Maine
    Great Info. I've been looking for one to replace the generator on my Farmall Cub tractor. Need a small one to fit up under the hood.
  6. lht
    lht
    if its a sbc you didn't say just get a delco and bury with a low mount
  7. petritl
    petritl
    from Marion, TX
    If it is a SBC the water pump with built in alternator will work.
    I know some small Perkins Diesel engines have a very small permenant magnet alternator, as I recall they are about 4" on diameter and a few inches thick.
  8. captmullette
    captmullette
    got a denso off ebay, fairly cheap. got a top notch bracket off a fellow hamber idahodave, he has them made......
  9. GREASER815
    GREASER815
    I have a little one that I have been saving but not going to end up using. I think it will work out perfect for what you want to do. PM me if your interested. I can take some pics of it.
  10. BobF
    BobF
    from Poway, CA
    Look for a Japanese Chevrolet Sprint or Metro (3cyl 1.0 L) in the bone yard. They came with a very small alt used by a lot of racers. If you have to get one from one of the common parts stores they are over $100.
  11. borderboy1971
    borderboy1971
    from Canada
    I'm not sure of the amp rating, but the alternators for a 87-93ish chevy sprint (3 cylinder version) are rreally tiny. The ones I've pulled off have a serpentine pulley on them though. The suzukis samuri or chevy tracker might be the same, but not really sure exactly.
    Haha, I was too late.
    Chevy sprint=Geo metro=pontiac firefly=suzuki swift (all the same car) but the 4 cyl engines used a different alt.
  12. Fenders
    Fenders
    Kubota tractor alt.
  13. Kirk Hanning
    Kirk Hanning
    Suzuki Samari, auto parts stores carry them on the shelf. Run a battery wire then a 12v ign wire and its done. As said before it comes with a single v-belt pulley.
  14. designs that work
    designs that work
    On Epay the small alternators are called Mini Nippon denso type, 45 amp single wire but a little pricey, over one hundred dollars. Have run one my avatar for 5 plus years.
  15. wisdonm
    wisdonm
    Like Fender says, we run the Kubota fork truck units both on the street and in our road race cars.
  16. mart3406
    mart3406
    from Canada
    A lot of the homebuilt aircraft guys,
    particularly, those building lightweight
    planes with VW or Corvair power, use
    an alternator from a John Deere garden
    tractor :)eek:!) that is really, really small.
    There's some pics and info on it here.
    www.n56ml.com/corvair/dynamo.html
    Mart3406
  17. sorry for this newbie question but do you mean that there are some water pump with alternator inside ?
  18. garvinzoom
    garvinzoom
    That JD alt. looks like the ones used on small Kubotas.
  19. petritl
    petritl
    from Marion, TX
    This is the same as the Perkins units.
  20. petritl
    petritl
    from Marion, TX
  21. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Great ideas, I will be looking soon for an alternator for my 5w Coupe. Subscribed!
  22. gnichols
    gnichols
    from Tampa, FL
    Man, there is some interesting info here. I'd guess there aren't any small units like the ND version that have more amps (50-60?) then? Gary
  23. brady1929
    brady1929
    Man there is some good info here
  24. captmullette
    captmullette
    the denso's are smaii and you can pick your amps......
  25. Phil1934
    Phil1934
    I bought an 80 amp for a Suzuki Grand Vitara and swapped pulleys. Late '80's Toyota 4runner is 95 amps and v belt pulley. There are rebuilt units on Ebay with 130 amps, but I wonder about that much output in a small package. A search of Denso alternator on Ebay will show a bunch of outputs.
  26. Yo Baby
    Yo Baby
  27. Idaho/Dave
    Idaho/Dave
    from Idaho
    I bought this off Ebay,look under gm mini alt. 60 amp.single wire, I have the brackets made, first 2 pictures are 34 ford, last pictures are model A.
  28. gatz
    gatz
    I realize it's a bit of a WAG, what kinda amperage are we talking for a "conventional" rod with typical lights, AC and perhaps a Kenwood system, but not an outlandish power-hungry audio?
    Would 60amps do it?
  29. Cool info, am looking for one for my RPU,cheers. JW :)
