slick 60's f100 steering linkage
Discussion in 'The Hokey Ass Message Board' started by few loose bolts, Mar 21, 2012.
  1. few loose bolts
    few loose bolts
    from US
    anyone ever replaced the steering linkage in a 61-66 f100 with heim joint tie rod ends? trying to get rid of some of the slop in the steering. i know ultimately it's the wide ratio in the box, but i was thinking that this might help a bit as well as being a lot stronger. i do plan on replacing the bushings in the front suspension as well as putting in a proper universal joint at the column. but wanted to throw a line out there to see who's done this and results.
    cheers.
  2. tjm73
    tjm73
    I think if you rebuild it with OE quality replacement parts a lot of, if not all, the slop will go away. By rebuild I mean every thing from the steering box to the spindles.
