Size Differences:
Discussion in 'The Hokey Ass Message Board' started by Irish Dan, Apr 1, 2012.
  1. Irish Dan
    Irish Dan
    Is there a big difference between the sizes of a GM TH200 & GM 200R? How do either of these trannies compare in size with a GM turbo 350?
  2. squirrel
    They're all pretty similar, same overall length. The pan on the 200-4R is very long, and the mount is at the very back of the transmission, so you might need to do some crossmember work to make it fit. The 200 is the narrowest of the bunch.
    There are some longer tail housing 350s
  3. chubbie
    chubbie
    CK memory:confused: the 200r4 mount is 6 5/8" back from the 200 and 350 trans. the shift shaft is a few inches back also. same length drive shaft
  4. Irish Dan
    Irish Dan
  5. Weasel
    Weasel
    200 4R mount is 1 5/8" back from TH350
