Projects Since its not broke why fix it
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Oct 14, 2020.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    I have 7 cars that I drive, and have driven some for decades with drum brakes and ignition points and bias ply tires. I have taken several of them on trips to other states for events with no issues. Also I can't remember the last time I adjusted a set of points after I initially installed them. The last set I replaced in my 61 Impala just because they had 30,000 miles on them and they still looked and were working fine. Adjusting drum brakes? I give the wheels a spin when I am under it changing oil and greasing the ball joints etc, if they need adjusting it is 5 minutes tops.... If there is one thing I don't mind is doing periodic maintenance on my old cars, Hell it's kinda relaxing to me and I think it is part of the deal owning old cars. Personally I like driving vintage cars that aren't all modernized, makes me feel closer to the pioneers of hot rodding and I feel more connected to the road...
  2. Budget36
    Budget36
    See, I'm fine with disconnecting from my past. I'll take self adjusting brakes, etc...and just change the oil. Now if they'd come up with a sealed front wheel bearing I could use, I'd be golden.
    Been digging around too much in the grease and dirt in my life. If I can make it easier on me, I'll do so.
  3. BamaMav
    BamaMav
    from Berry, AL
    I kept my Lincoln brakes but did go with a dual master with power booster. I also added power steering because it's a big heavy car and the box was worn out. It was fine on the road but hard to turn in town. AC is in the long term plans, too
    . Got a cheap radio to hide in a console one of these days. May never even turn it on, I'm usually happy to just listen to the exhaust rumble...
    TrailerTrashToo likes this.
  4. junkyardjeff
    junkyardjeff
    So far the only vehicle I had that I was glad to get rid of the original brakes is my 37 Chevy p/u,a pain to adjust and did not have the tools to adjust correctly so it did not stop too good. I was also glad to get rid of the original drivetrain in the 37 too as now I can go 75 on the highway but most of the other older cars I had were good they way they came.
  5. junkyardjeff
    junkyardjeff
    Was rethinking my idea on keeping the points today when I found out I had a worn out distributor,found a good one in stock so staying points for now.
    guthriesmith likes this.
  6. No Cents
    No Cents
    hey wait ..... that's my motto.
    Lone Star Mopar likes this.
  7. spanners
    spanners
    If drums are working fine at the 'strip, the only thing I would do is a dual brake master cylinder so if there's a leak in one circuit at least you've peeled off some speed before the catch net.
    olscrounger likes this.
  8. vtx1800
    vtx1800
    I've upgraded the brakes twice on the 38 Chev, went to disc brakes, then bigger disc brakes and granted it had been 30 years between driving the car with 54 Chevy drum brakes to the disc set ups but I don't think my stopping power got better. When I built the Stude I upgraded it from a six cylinder light frame to a Hawk frame, bigger finned drum brakes, I did add a dual master cylinder but other than that, the suspension, steering and brakes are 1958 Studebaker Hawk. It stops better than the Chevy. Using the org tapered axles too, I am a glutton for punishment:(
  9. junkyardjeff
    junkyardjeff
    When winter is over and it gets new tires I will put some miles on and see how it does and decide if it needs any upgrading then,everything seems to work fine for around town driving but the tires are so rotten I am afraid to take it out of the city so it has not been on the highway.
  10. jimmy six
    jimmy six
    Since I talked about it and didn’t go to Florida to visit our daughter and her family over the holidays. I had the AC put in. To most it would have been a goat f**k but it ended up turning out great. I finished the glove box today and since it was 47• when I went off at 5:30 am the new heater was way better than the original. This summer I’ll find out about the AC.
    The best thing I found out, I borrowed my sons DC amp meter and started turning on each load. The highest was headlights, AC on high fan, radio, and stepping on the brakes for the higher wattage lamps and the load was 34 amps on the line heading to the ignition switch which is a # 10awg. Ever other test was lower and I’m pretty sure I won’t be driving at night with the AC on much. At the end I also checked the amperage coming to the battery at idle with the 34 amps and it was 1.8 amps and the voltage was 13.8 vdc.
    stillrunners likes this.
  11. lippy
    lippy
    from Ks
    You do remember why you are here right? Lippy
  12. jimmy six
    jimmy six
    Most of the time... but on this thread I’m a guy who seems to “fix” things that are working just fine..even if they OT...:(
  13. Many times upgrades like welded in Mustang II frontends ruin the car and don't really work or ride any better, watch out what you do to these old cars and refer to the little books from the 50's for how it's done. Hopup, Honk, Custom Car, Carcraft, then you won't go wrong. Also some things are a "dead giveaway" , tilt steering columns and modern seats are for "Old Fat Guys" so don't build a car that will bust you as one. HAHAHAHahahahah!!!!
    MO54Frank likes this.
  14. 49ratfink
    49ratfink
    the problem with the "just fine" brakes we have on these heavy old cars is that the late model in front of you has super-duper extra fine brakes.
  15. 49ratfink
    49ratfink
    here in the real world they work much better than what they replace. show me one example of a properly installed MII that was worse than the original equipment. they have been around for 30 years now. sure, they are ugly on an early car but you didn't say they were ugly.
    gimpyshotrods likes this.
  16. Thanks, you said it for me, properly installed? and for sure uglyJW
  17. 59Apachegail
    59Apachegail
    from New York
    I went disc because people on the road can be distracted and inconsiderate. I live in a heavily populated area. If that were not the case I probably wouldn’t need them.
  18. gimpyshotrods
    gimpyshotrods
    Same here.
    They are not only distracted and inconsiderate, but often drive cars that exceed both the maximum coverage of my insurance, and the value of the average HAMBer's house.
    warhorseracing likes this.
  19. junkyardjeff
    junkyardjeff
    If I find a deal on 77-9 T bird disc brakes and a FE Duraspark distributor I am going to grab them in case I do some upgrading in the future but other then a modern stereo its going to stay the way it left the factory for now,the first idiot who pulls in front of me and slams on the brakes might change my mind.
  20. Pretty much nothing on the '38 Ford pickup is stock other than the body and front suspension (beam axle with a disc brake kit). My '55 Ford, on the other hand, is staying closer to stock. Some things will be changed: I don't get pangs of nostalgia for 6 volt electrical systems or vacuum wipers. I am old enough to have driven in a torrential rain with vacuum wipers. It wasn't fun then, and the passage of time has not made me want to do it again. I have rigged up electric wipers with junkyard parts (I forget what the wiper motor came out of, but it's written down in a notebook I keep in the car). I fabricated what I needed to mount a GM internal reg alternator on the Y-block. Found a radio delete cover from a '55 that didn't have a radio--I would have kept the stock radio in the dash for looks, but that thing takes up a lot of space under the dash and was in the way of the electric wiper motor. Will be building a small under-dash console with a stereo AM/FM/CD and gauges to replace idiot lights. Have a '57 distributor with fresh points and condensor. The 272 and 3 on the tree stays. LED bulbs in the taillights and a third brake light in the back window. The third brake light is in a black plastic housing that matches the black vinyl on the seats and package tray, unobtrusive but does what it's supposed to do--everything newer than '86 has a third brake light, today's drivers (including me) have gotten used to them and they reduce your chances of being rear-ended. Seat belts because I cracked my sternum in a wreck in that car back in '68 and don't want to do that again. Aerostar coils on front and 1 1/2" lowering blocks on rear. Otherwise pretty much stock mild custom.
  21. 57JoeFoMoPar
    57JoeFoMoPar
    I have 3 cars that I drive; one with stock steering and brakes, one with stock power brakes but steering converted to a 72 Nova power box, and one with Scarebird power discs and a new Borgeson steering box. I can tell you the better equipment makes the car drive and stop better. Period. In terms of significance of improvement, I don't see anything wrong with factory steering and suspension, especially provided that it's functioning properly. I can't say the same for brakes. Even rebuilt and properly functioning drum brakes on a full size car do not work as well as a disc set up, which has little to no fade or pull, even after multiple stops from highway speed.
    Engine wise, I've found there to be a significant improvement in performance, cold starting, etc. with electronic ignition over points. I don't think it's change for the sake of change.
