simple weld/fabrication question
Discussion in 'The Hokey Ass Message Board' started by kscarguy, Apr 2, 2013.
  1. kscarguy
    kscarguy
    What is the best way to do this...?
    I have to weld a small 1/2" wide tab onto a bracket. Both pieces are 1/4" thick. The tab set on top of and aligns along the edge of the bracket.
    Should I bevel the edges of the small tab (or bracket) before TIG welding the pieces together, or am I better off just fusing the pieces together where they align without using filler rod?
    I would rather not grind any weld off, but just have a good looking weld.
    (sorry for the crappy picture, my camera is barely working)
  2. Ted H
    Ted H
    I would recomend beveling both sides of the small tab. 1/4"is a bit thick for "fusion" weld.
    Ted
  3. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    A bevel on it, and if possible TIG weld it. Otherwise crank up the heat and MIG it.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    That's a pretty common weld to perform, and I agree that a slight bevel might help penetration. Tigging will give you the smallest, prettiest weld, and probably the strongest too. Use filler rod , and clean all the parts shiny clean before welding.
    Don
  5. hooliganshotrods
    hooliganshotrods
    from Calgary
    Agreed, a small bevel and tig USING filler rod. Autogenous welding on thicker sections is a bad idea.
