Side trim problem
Discussion in 'The Hokey Ass Message Board' started by Super88, Oct 1, 2009.
  1. Super88
    Super88
    When reinstalling the side trim on my Olds, I've found I can't get the push-in clips to engage. It appears the clips move enough to prevent engaging. This would explain why I found chunks of cardboard under the clips when I removed the trim. Since cardboard would hold moisture, how can I prevent the clip from moving?
  2. 49ratfink
    49ratfink
    get new clips? try your local paint supply store.
  3. Take an old butyl windshield kit, break off a piece and make a ball. Cram it under the clip. Dum-dum(plumber's putty) will work too---whichever is easiest(read that, "whichever's laying around the shop")
  4. Super88
    Super88
    Thanks guys. I replaced the bad clips with some I bought from a vendor at BTT50's, but even those have enough movement when you press on the trim to keep them from snapping in. I'll see what I can find to put behind them. I didn't like the cardboard idea because several were quite rusted and I think it was because of the cardboard holding moisture.
