Technical Show Me Some Dressed Up Flathead Six Cylinders
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Jan 19, 2016.
  1. Speed Gems
    Speed Gems
    I know we already have a thread for six cylinders here and I'm limiting my thread here because Chevys were mostly OHV engines but show me your dressed up Flathead six cylinders. Finned aluminum head, Multi carbed manifold , spilt exhaust manifolds whatever you've got.
    Flat Six Fix likes this.
  2. Speed Gems
    Speed Gems
    I forgot blowers too if you got one.
  3. My 226 Ford, Nicson intake, Knudsen head, home built split manifold, Petronix Ignition
    6inarow, Spooky and Speedys Garage like this.
  4. Speed Gems
    Speed Gems
    Back To The Top.
  5. andydodge
    andydodge
    This is a Plymouth 230 that I was building for the 41 Plymouth Coupe I had.....sold both a few yrs ago.......Edgy head, offy intake, unknown finned sideplates, Oz GM Holden Stromberg carbies,, adapted Holden water pump, modified & split cast iron exhaust manifolds, HEI & Beehive Oil Filter on original engine pic..........andyd
    6inarow and Spooky like this.
  6. Fortunateson
    Fortunateson
    That dual intake engine looks great.
    When I get back to my cantankerous '42 Fargo I want to install an Ellis 2 carb intake that I have but first need someone to advise on a couple of points. I will also install a "Spitfire" head; can't afford an Edgy one the way the CDN doLiar is right now.
  7. Fingers
    Fingers
    And those Mopar flathead sixes sound so good too :)
    Spooky likes this.
  8. Flat Six Fix
    Flat Six Fix
    Nice lookin engine you got there.
    Can you tell us a bout it, shaved head, hot cam etc?
    Can you give me a comparison to the same car and a stock engine for get up and go and performance?
    I am about to embark on souping up my flathead 6 with George Asche goodies.......
  9. Smiffy
    Smiffy
    1938 Dodge six running triples and a hot cam etc from about 42 years ago bit of a sleeper.
  10. Flat Six Fix
    Flat Six Fix
    Goes good I take it, what is it like compared to stock?
    HEHEHE, just realized this is from a magazine article 1973
  11. Bone stock right now. Home built three carb aluminum manifold and split exhaust manifold. It runs well but still a lot of tuning to do
  12. Flat Six Fix
    Flat Six Fix
    So with split exhaust/ or headers, these engines really should wake up when they can exhale more?
    How is it when you hit that throttle wide open, should go a lot better, on the highway...
  13. hkestes
    hkestes
    from Plano, TX
    6inarow, Spooky and coffman like this.
  14. coffman
    coffman
    '47 Plymouth w/ '54 Chrysler 264ci,balanced&head cut.125 cleared for valves, Factory 2.5" '51 Dodge truck intake&exhaust,2 barrel Webbers,custom hiem linkage.
    6inarow, 504640, Spooky and 1 other person like this.
  15. Flat Six Fix
    Flat Six Fix
    How does she go?
  16. Katuna
    Katuna
    from Clovis,Ca.
    Puck-a-da, puck-a-da, puck-a-da.
    Spooky likes this.
  17. hi guys here is my 59 Desoto 250 inch flathead 6 with 3 x holly 94s and headers that I am putting in a roadster pick up DSCK0537 (2).JPG DSCK0537 (2).JPG DSCK0276 (2).JPG
  18. Flat Six Fix
    Flat Six Fix
    My engine as it looks now
    Spooky, Jose perez and Jet96 like this.
  19. Jose perez
    Jose perez
    I know and understand this is just showing off the engines. But if í may ask.... Who has changed out their original tranny to either a gm automatic or standard, and where, who did you guys get the housing/adaptors from? Again... I apologize if the question doesn't belong here. I traded my 49 Plymouth for a 51 coronet. Just finished the voltage conversion from 6 to 12. Im saving up to modify the 230 into what you guys have(shown above). But í want to start with the transmission if posible...Thanks again for your time and knowledge.
    Sent from my LG-K550 using The H.A.M.B. mobile app
  20. 28dreyer
    28dreyer
    from Minnesota
    Studebaker Champion 169 cubic inches alky burner.
    Jet96, 6inarow and Spooky like this.
  21. Cosmo50
    Cosmo50
    Try Wilcap.
    http://www.wilcap.com/chryslerfh.html
  22. Jose perez
    Jose perez
  23. Arthur
    Arthur
    from NC
    The "spitfire" head is just a standard compression head with a cool name. No extra HP. Save your money and use what you have until you can afford to be a Edgy head.
  24. Jose perez
    Jose perez
    Are the spitfire heads shaved though? Not sure how much but, í was under the impression that they were. Giving more lift room.... I picked one up at the Pomona swap meet for 40$...
  25. I put a S10 T5 in mine, really works good. I got the adapter from Paul Curtis.
    Jose perez likes this.
  26. Arthur
    Arthur
    from NC
    No. Just an advertising name. You can shave/mill them if you want though,and 40 dollars is a VERY good price for one. They do look cooler than just a blank head/
  27. Jose perez
    Jose perez
    Did you install it Your self ,Or had a shop do it for you? If you did it yourself what was the biggest issue you ran into?
  28. I installed it myself and it went together easily. No problems at all but you do have to get either the bearing retainer on the T5 turned down or open up the inside diameter of the throw-out bearing holder. I took a little off both. I believe instructions are included in the kit or on the website.
  29. Arthur
    Arthur
    from NC
    Sorry for the late reply. For some reason I didn't get a notification.
    No,the Spitfire heads aren't shaved,but you can shave the one you just bought .125 if it has never been milled before. For 40 bucks you got a good deal if the head isn't warped or cracked.
