show me pictures of how you mounted an in bed gas tank.
Discussion in 'The Hokey Ass Message Board' started by jdsludge, Jul 9, 2012.
  1. jdsludge
    jdsludge
    Looking for inspiration to mount a gas tank behind my cab, in the bed of my 1935 International. I have a universal 16 gal old style tank, so I want it visible.
    Any pictures would be helpful. Thanks:)
  2. GomezGarage
    GomezGarage
    plain and simple...speedway brackets...battery is in the toolbox...cant tell you how many people say "dont forget your toolbox, thats nice and will get stolen" hahahaha
    one thing i would change is i would mount the tank about an inch farther from the bed front...if i spill gas right now my hand is too big to get back there and wipe it up
  3. trollst
    trollst
    My 36 has the tank in the bed, I built a wooden box around it, added speaker grilles to the box, nobody knows its a gas tank.
  4. 1929 closed cab pu: Bolted it in toward the front, adding some solid braces under the bed
    I felt dealing with overflow and venting was important, so I made a little bucket to fit around the filler, ran the vent line to it and an overfill out and away from the exhaust.
    painted it
    built a plywood box for hauling stuff.
    then put a cover over it
  5. Muttley
    Muttley
    Yep, I got the one in my old '39 from them:
  6. hopped up
    hopped up
    from So Cal
    Good job! Ross b
  7. LockeGilber
    LockeGilber
    from new york
    [​IMG][​IMG][​IMG][​IMG]
  8. fatboys69
    fatboys69
    from Tennessee
    Its an aluminum military surplus tank, made some straps and used old trampoline springs to keep it held tight n anchored the straps to the floor
  9. fleetside66
    fleetside66
    A little angle iron crib & some early Model T steel straps from The Hot Rod Co. & that's it. I did line the inside of the straps with rubber to prevent metal on metal chafing. The tank is from a 1924 Federal-Knight truck, by the way.
  10. jdsludge
    jdsludge
    RussB,looks great! How did you anchor the tank? looks like there is no straps.
