Hot Rods Should I put her to BED?
Discussion in 'The Hokey Ass Message Board' started by Anderson, Apr 23, 2009.
  1. LarzBahrs
    LarzBahrs
    from Sacramento
    Run a bolt on, it looks sweet both ways!
  2. metalhotrodgirl
    metalhotrodgirl
    haha no he didnt .. but the bed would make a perfect spot for my pinstriping box :)
  3. gnichols
    gnichols
    from Tampa, FL
    I like a bed for trips - even short beds. Given the more aero style of your car, I'd consider a bed with a deeper well side - 32-34 Ford and raise it a tad so the top rails were a little closer in height to the contour lines on the body.
    I'm working out the same deal with my build... consider a hard cover with good seals / drains because the hole deal will fill up with water in a heavy rain.
    If doing a soft cover, you might consider some sort of "stylish" but completely removable set of bows / ribs stretching between the stake pockets, so that there will be a little wagon-top curve in a snap on toneau to help it drain. And to match the style of your top.
    Otherwise, just leave it open and pack your stuff in water-proof dry bags / weather resistant luggage!
    I could also see one of those vintage, fold-down luggage racks on the back looking good - with or without cargo. Water-proof gear will still needed.
    Or a trailer hitch and a very small (motorcycle sized) style teardrop / retro trailer? They might be too small, but worth a look. These are some of the coolest small trailer designs I've seen, mostly for bikes. The rest are mostly ugo-Goldwing things. Gary
    http://www.trurons.com/dasz/index.html
    http://dreamchasertrailers.com/_wsn/page2.html
    http://www.stema.no/
    http://www.dutchmans.com/
    http://www.golittleguy.com/cms/content/view/34/96/
  4. I'm almost certain I've seen this car. I really like it but it needs a bed. Run it!
  5. Hooligan63
    Hooligan63
    Which breaks down to 79 for yes,25 for both,11 keep it as is,4 for roadster deck,4 undecided,and if you want to go in to percentages,I would say ,make a removable bed that is functional and you can have it both ways,that way the majority votes are both happy,and your bed problem is solved and you're happy either way.
  6. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Looks awesome. Like another said, maybe deepen it a bit to the lower body line
  7. 50Fraud
    50Fraud
    I think ALL the versions shown look good, although my personal preference is Chopt34's turtledeck. Of the pickup bed versions, I prefer the higher/longer one; it balances the mass of the body the best.
  8. artemas
    artemas
    definitely original- go for it
  9. Clutched
    Clutched
    DO it! i like with the bed.
  10. A-Wall
    A-Wall
  11. CJ Steak
    CJ Steak
    from Texas
    I really like it the way it is, but the bed really completes it.
    I would make the bed removable though... just incase you get the hankering for that modified look though.
  12. Anderson
    Anderson
    Thanks again folks.
    Yes, this is going to happen. It's going to be in line with the belt line on the car, and I think it will probably be the longer version of the bed....this one.
    I'm pretty tied up with another project right now and for the next couple weeks, so I don't have the time or cash to start on the bed yet. But it will be done as soon as it can be!
    Any leads on a cheap bed would be appreciated.
  13. frankenstein1948
    frankenstein1948
    I like it better as a roadster pickup,so another vote for the bed.
  14. SlowandLow63
    SlowandLow63
    from Central NJ
  15. Tman
    Tman
    That last Photoshop has it! Cool.
  16. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    Wow! Amazing how fast you are able to create/fab this stuff. The bed will look great!
  17. hemifarris
    hemifarris
    The bed makes it!!! Great hot rod by the way! ...Mike
  18. skwurl
    skwurl
    It looks great either way. I would make it removeable like you said. You can have 2 hot rods!
  19. Irrational Metalworks
    Alliance Vendor
    from DFW
    The longer bed looks the best IMO. I think it looks real good. Build it yourself, and save some money! You can do it , just buy or find a tailgate and some stake pockets, and your good to go.
  20. keep the bed removable, go for it
  21. Ryan
    Ryan
    ADMINISTRATOR
    from Austin, TX
    Wow... I liked the car before, but I'm starting to love it. The bed is brilliant.
  22. Anderson
    Anderson
    No, nothing yet. Been working on this thing with a bed...
  23. Go with the bed!!
  24. Fidgiter,
    The bed is a cool idea....removable is an even better one! Sorry I didnt see this sooner...
    For removal, how about 2 Reese-hitch-type receivers...female on the frame and male on the bed. Two pins and it's off (or on)!
  25. there is nothing you could do that would screw up the looks of that ride. just drive it add a little from time to time to keep it fresh for you.
    that said I wouldn't make the bed deeper. maybe a roll pan that hid the tank ect.
  26. SanDiegoJoe
    SanDiegoJoe
    it really balances it out - can't wait to see it done... I like the longer version.
  27. jm36072
    jm36072
    It looks good with the bed, but if you made it removable that would be cool!
  28. Scrumpy
    Scrumpy
    from NH93 Exit1
    I like it with the bed. Gets my vote. If you do it can you bead the bedside to match up with the bead around the louvers on the hood side? Not neccessarilly the same shape to the front edge but just using the same bead shape and size.
    Scrump
  29. Anderson
    Anderson
    Well, I picked up a Model A bed from BenD a couple weeks ago. Started cutting on it last weekend, didn't get far. But I'm hoping to get a lot of it knocked out this weekend and next week. It'll have the factory beads in the bed sides, much like the photoshop.
    It won't be removeable. I mean it can always come back off and be changed back, not going to weld to the frame any...but i don't plan on switching back and forth any. I'll post pictures when I have something to show!
