Should I buy this? Gray marine diesel - what yr?
Discussion in 'The Antiquated' started by Fstarocka, Jul 11, 2021.
  1. Fstarocka
    Fstarocka
    Up for sale - $200. I dont really have a use for it because its way b4 my time - but looks like a cool little side project to tinker with -
    its a gray marine Model 118 diesel
  2. bigdog
    bigdog
    Never saw a diesel with spark plugs.
  3. I don’t believe it’s a diesel. But I have seen ones by International that started on gas then switched to diesel. Some old farm tractors started on gas and switched to tractor fuel when warmed up. He could Google it and find more about it.
  4. Wrench97
    Wrench97
    Ya that's not a diesel. might be flat head Continental 6 banger.
  5. TrailerTrashToo
    TrailerTrashToo
    Fstarocka likes this.
  6. Doublepumper
    Doublepumper
    Continental six gasoline boat motor.
    They're heavy and tough. I've seen them used to power lots of different things, air compressors, generators, pumps. I've also seen them converted to air compressors. Some of them even came with dual carbs.
    Some of these engines are sought after by the wooden boat folks for restorations.
    tractorguy likes this.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Post it on a boat restoring / classic boat forum, I'm guessing there'd be some value there. IIRC , those engines are bulletproof !
  8. Mr48chev
    If you have an antique boat to put it in it might be a good buy. Or if you just like old engines and plan to put it on a stand with a radiator and have a running display engine.
    That said, if it is good shape and runs there is probably a market for it with the old boat folks if you are willing to hang on to it for a while. Gray Marine – Welcome
    eBay item number:
    265098751702 This one is a 4 cylinder.
  9. Budget36
    Budget36
    Interesting, I don’t see any carburetor (s)
  10. squirrel
    I think it's an updraft carb, hiding under the manifolds
    Tim and Budget36 like this.
  11. Wrench97
    Wrench97
    Should be dual updrafts under the water cooled exhaust manifold.
  12. v8flat44
    v8flat44
    Those things run forever. Could have twin carb setup or not. I've owned & been around Gray engines all my life & loved them all. The V8 versions were American Motors blocks except for one that used Buick.
  13. Fstarocka
    Fstarocka
    oh my I completely didnt pay attention to the plugs! Looks pretty clean - think ill go get it this week.. just for kicks if anything- yes would look beautiful in a classic old wood boat (30s era chris craft?) - any idea what model carb/ etc would be found on this? and what era this would have come from? I did read that gray marine made alot of engines for war boats -
  14. Wrench97
    Wrench97
    That looks like late 40's early 50's vintage.
    Hnstray likes this.
  15. Hnstray
    Hnstray
    from Quincy, IL
    Interesting history on Wikipedia. My first introduction to Gray Marine was in the Navy where I occasionally crewed on landing craft and V-bow utility boats. I served on a Destroyer, but we would ‘rent’ one of those craft from the Navy shipyard in in Long Beach to use like a pickup truck for certain tasks. The model I mentioned above were Gray Marine diesel…actually GM Detroit Diesel 6-71 series, converted to marine use by Gray. The landing craft had twin engines and the utility boat a single engine. Twins were counter rotating and the Coxswain could put that LC anywhere he wanted by manipulating the rotation with the gear box (forward/N/reverse) and throttle. The wet exhausts were unmuffled and boy did they bark when given their head. Fun memories.
    Ray
    tractorguy and TrailerTrashToo like this.
  16. MeanGene427
    MeanGene427
    from Napa
    Well here's a new experience for you then. There are better overall videos of a TD24. but this one shows the gas system on one side, diesel on the other. Pretty good beast when new, size of the early D9 Cat. One of the dozers at the end of "Vanishing Point" was a TD24, and there was also one burying critters in "Hud"
    VANDENPLAS and tractorguy like this.
  17. MeanGene427
    MeanGene427
    from Napa
    Here ya go- starts on gas, runs on diesel. TD24 was a beast in its day, size of a D9 Cat. One of the dozers at the end of "Vanishing Point" was a TD24, and there was also one burying critters in "Hud"
  18. 1952henry
    1952henry
    All of the old International/Farmalls started on gas. Once warm, over to diesel.
    Okie Pete likes this.
