Technical Short Radiator for a Channeled Car
Discussion in 'The Hokey Ass Message Board' started by Stock Racer, Mar 18, 2019.
  1. Stock Racer
    Stock Racer
    I'm struggling with radiator height and trying to avoid mounting it in front of the crossmember. We're talking Model A style with a Small Block Chevy. Speedway has one listed as 20"-21" overall height. Anyone know of anything shorter? I know there are lots of threads on this, I've looked at a bunch of them. Just wondering if there's any new info in Hamb land.
  2. Jim Bouchard
    Jim Bouchard
    Stock Racer and flynbrian48 like this.
  3. zzford
    zzford
    Check for industrial type radiators. Some of them for forklifts, tractors etc come in some odd sizes. Most radiator shops have catalogs where the radiators are listed by dimensions.
    Stock Racer likes this.
  4. Mr48chev
    Check with these guys. They sell radiators on Ebay but also build radiators to what ever specs you need within reason. They aren't the cheapest by a long shot but aren't the most expensive either.
    https://www.cgj.com/
  5. 41fred207
    41fred207
    I used a model T radiator I scored at a swap meet for $50.00 in my 4" chanelled A. Width was just right for my original grill shell, just had to notch my spring cross member for lower hose outlet.
  6. 41fred207
    41fred207
    Just re-read your post, sorry, I am in front of cross member, hence the notch..
  7. s55mercury66
    s55mercury66
    from SW Wyoming
    You might look at sprint car or midget radiators.
  8. AndersF
    AndersF
    I had the same problem but at least left some space to drop the radiator behind crossmember.
    But i have both channel and a z on my frame.
    But i find a alu one for a Datsun fairlady that was small enough and supposed to handle 350 hp.
    Should be enough for my stock 55 Dodge engine.
    To find mine i was looking on ebay searching radiator and scrolling and looking on
    dimensions until i found one thats work.
    Stock Racer, Just Gary and Frankie47 like this.
  9. ramblin dan
    ramblin dan
    1960 1961 1962 chevy 6 overall 18.75 x 22.75  from gearheadworld.jpg from speed daddy 14 x16 3 core rad for 101.00 free ship.jpg 1960 to 62 chevy 6. 18.75 x 22.75. Or Honda Civic, 14 x 16.
  10. Stock Racer
    Stock Racer
    Thanks to all for the responses. Anyone else?
  11. chopndrop
    chopndrop
    Speedway Lo-boy 32 radiator was the shortest I could find a year or so back when I was looking for my channeled T. Lots of cheaper no name aluminum radiators all over ebay, but all were taller. Looked a bit at forklift and tractor applications but nothing that seemed worth the effort to make them work. I talked to local radiator shop about making one. Was going to use Model A tanks (was using Model a grill shell) and use a shorter core. Also would need to move around the hose fittings. He could make whatever i wanted, but was going to cost a lot more.
    https://www.speedwaymotors.com/6-Inch-Chopped-1932-Lo-Boy-Aluminum-Radiator,7367.html
