Shooting Lacquer with HVLP, Tip Size ?
Discussion in 'The Hokey Ass Message Board' started by Sixcarb, Mar 24, 2011.
  1. Sixcarb
    Sixcarb
    from North NJ
    I have a Sata hvlp gravity gun and want to shoot a solid color lacquer, does anybody have a good idea on what tip size works the best, my gun has a 1.3 right now so I'm hoping that will work out ok. I was thinking at least 30 lbs of pressure.
  2. colordeluxe
    colordeluxe
    A 1.3 might be a bit small, meaning you may have to spray too slowly to get a good result with lacquer. If you are not spraying too large an area it may be fine. Otherwise a1.5 or 1.6 gives me good results.
  3. I've never done lacquer with a hvlp gun, but would check the lacquer manufacturers application sheet...it'll give you all perimeters needed, tip size, pressure, temp, humidity, etc.
  4. bobkatrods
    bobkatrods
    from aledo tx
    what model SATA?
  5. "Inquireing minds want to know"...
  6. Sixcarb
    Sixcarb
    from North NJ
    Sata jet 3000 B HVLP
  7. pimpin paint
    pimpin paint
    from so cal
    Hey,
    You're gonna thin that lacquer to about 150% arn't you & the smaller tip should work, but a 1.5 would work much better.
    That 30 lbs. you're talkin, is that at the gun?
    " Humpty Dumpty was pushed "
  8. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    I spray basecoat with a 1.3 all the time. it should also work fine with Lacquer.
  9. bobkatrods
    bobkatrods
    from aledo tx
    LIKEWISE,, i spray base with 1.3 jmo i think the atomization is better with the 1.3,,10 lbs at the tip and slow up your speed. i use the 1.3 on lacquer that i spray on non automotive product. I thin it 150-200 % sprays great.
  10. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Use an old gun ,Thats what I was told.Diferent atomization in newer paints......
