I already got 2 inch blocks wanna try gettin low as possible on the cheap . Bigger blocks and I heard remove a leaf or 2 what leaves can go?
Dont go more than three inch blocks, unless you like not being able to remove wheels when you get a flat. I think repositioning the spring hangers at the back is a good way to go, along with a small notch to lift the bump rubbers up level with the rails. Maybe one leaf out too. This will get you about 3 1/2" off the deck at the rear of the rocker panel, which is about where they look best. Unless you are into airbags and broken stances.in which case, i Cant help you.
