Projects Shoebox ford skirts are rubbing the tires.
Discussion in 'Traditional Customs' started by ab_51Ford, Apr 29, 2024.
  1. ab_51Ford
    ab_51Ford
    Anyone had trouble with their skirts rubbing the tires? I think they are foxcrafts. They were close when I first installed them so I actually notched the skirts themselves right where the tires would be closest. It has the original rear end, so it's not wider, 670-15 tires so not extra wide either. Do I just need to massage the bottom sides out a bit more? I'd appreciate any advise.
    - Andrew
    3quarter32 likes this.
  2. 19Fordy
    19Fordy
    Body sway causes the rubbing.
    Rather than notching your skirts, could you change the backspacing of the wheels?
    OR
    Curve the bottom lip of the skirts outward just a little to provide more clearance. This may require cutting and welding so as to recontour the present bottom lip of the skirts.
  3. I don't have any advice on your skirt problems, but I do like the way the ass end of that Ford looks!!
    What rear bumper are you using?
    Uribe likes this.
  4. I had the stock Ford and Mercury cut down skirts on my 49 Ford Coupe... never had a issue,, hmm
  5. eaglebeak
    eaglebeak
    Because the body curves in from the halfway mark and down, this puts the skirts closer to the tires.
    Maybe?
    Either raise the back end or cut the skirts.
  6. Oneball
    Oneball
    What’s the condition of your spring and shackle bushes like?
    Tim likes this.
  7. alchemy
    alchemy
    Shoebox Fords came with 6.70 tires? Sounds big to me, but I’m no expert.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup shoebox Fords came new with 6.70's. Are the wheels stock or maybe wider???
  9. miker98038
    miker98038
    I went thru that problem on my 55 bird at one point. It only rubbed on the left side on a left turn. Careful measuring showed the body wasn’t centered on the frame. On a 4 post hoist with the body lifted and some dunnage and bottle jacks, and the bolts loosened (I could get to all of them, and none were frozen) I was able to shift the whole body. Surprised me how easy it was. Next step is to look at the room for backspacing and move the wheels in if possible. As above the shackles and bushings
    That looks too good the way it is to modify the outside.
    williebill and Oneball like this.
  10. ab_51Ford
    ab_51Ford
    1954 Lincoln
    leon bee and Jrs50 like this.
  11. ab_51Ford
    ab_51Ford
    Air ride and a triangulated 4 link
  12. ab_51Ford
    ab_51Ford
    Stock wheels
  13. Oneball
    Oneball
    Still worth checking the bushes or Rose joints. Even if they’re not that old.
  14. Mitchell Rish
    Mitchell Rish
    from Houston MS
    If centering the body doesn’t help consider this. 3/4 X 3 inch strip of mulberry or Bo dock. Cut a slot mid way on the 3/4 side. About 1/2 deep. Sand a radius to the amount you need to clearance. Very gently roll it to clear. Did this on my 57 Chevy and it radiused the lip perfectly and didn’t touch the paint. ( my paint was xxxx anyway )but you get the point. I gained 3/4 of an inch on distributor to firewall clearance on a 57 simply by loosening the body bushing and shoving backward so do not rule the previous suggestion out.
  15. Bend them out in the middle about 1/2 in and they won't rub
