Shoebox Ford Hood Hinge Spring Attachment
Discussion in 'The Hokey Ass Message Board' started by Racrdad, Jun 7, 2013.
  1. Racrdad
    Racrdad
    Anybody have a pic they can share with me on where the bottom of the hood hinge spring attaches on a 1949 Ford car? No springs were with the car, I have springs now but cant figure out where the bottom attachment point should be!
  2. 432bullet
    432bullet
    I don't remember springs on the shoe box Fords ?? They had a prop rod for the hood. :confused:
  3. wheeltramp brian
    wheeltramp brian
    yup no springs on a shoebox ,just prop rod
  4. Racrdad
    Racrdad
    Prop rod holds the hood up, yes. BUT - there are springs on the hinges that pull downward to pull the back edge of the hood into place and hold it tight again the cowl seal.
  5. flatheadpete
    flatheadpete
    from Burton, MI
    I can snap a pic when I get home. I went through the same thing......
  6. geemann51
    geemann51
    Please do, I'm interested in seeing this as well. Thank you...
  7. yblock292
    yblock292
    Yes that is correct, bottom of the spring fits into a slot in the flat panel directly below the hinges, just keep the back of the hood from "floating"
  8. the-rodster
    the-rodster
  9. Racrdad
    Racrdad
    I thought that's what the slot was for and put one spring on like that. The spring was so tight I thought it was going to damage the hood. Thanks for the info!
    Pics are working, spring in the pic looks stretched a lot like the one I installed as mentioned above. Thanks!
  10. 49 ers had a lot of weak spots like the hinges, hood, door latchs etc. Grille is my favorite thou.
  11. happy hoppy
    happy hoppy
    My 1950 coupe. I hope it helps. This is as I got the car, before I took it apart. the spring just pulls the hinge backward when closing. It does not hold up the hood like a chevy hinge spring does.
