Technical Shoebox Dropped King Pins
Discussion in 'Traditional Customs' started by Chop50, Oct 6, 2021.
  1. Chop50
    Chop50
    Hi All,
    Anyone out there running a Jamco or other dropped king pin front end? If so are you running stock drag link and pitman arm. Have you plenty of thread adjustment on your tie rod ends.
    My old Jamco setup the tie rod links are within just a couple of turns of bottoming out on the tie rod end side, at both sides before I get the toe correct. Very little adjustment to correct steering wheel position etc.
    Thanks, Steve
