Anyone have good advice for adjusting the alignment of the doors on a shoebox? Poorly aligned body panels drive me nuts. There doesn't appear to be any adjustment designed into the system. Thanks -Rot'n
Strategically placed washers or shims between the hinge and door or door pillar have always done the trick for me.
make sure your pins are tight then i usually bend the door to match the body, sometimes it takes some major "tweaking"
