Technical She's got some rack.
Discussion in 'The Hokey Ass Message Board' started by Joe Romano, Sep 4, 2015.
  1. Dirty mind bring you here????
    Seriously, I have a Mustang 2 rack and pinion steering that's about 15 years old and a brand new GM p/s pump.
    I installed the 3 shims that the pressure reduction kit states should be what is need for this application. (1000 lbs.)
    But!
    To me the steering feels like it's too sensitive.
    So, should I add another shim(4) to make the pressure 850 lbs.
    Or, take a shim out and increase the pressure to 1100 lbs. ?
    To my way of thinking, add another, that's what I started all this, adding shim's.
    Again, I would like to thank in advance all that take the time to reply.....Joe
  2. treb11
    treb11
  3. Hnstray
    Hnstray
    from Quincy, IL
    If you have a genuine Mustang II rack, they are noted for this problem, regardless of pressure reduction. The more popular racks for MMII suspensions are those from the mid to late '80s T-birds and the Mustang R&P from '89 thru '93.
    Ray
  4. i.rant
    i.rant
    1. 1940 Ford
    I used the replacement valve and it made a world of difference although I purchased mine at Detroit Speed. Prior to that I felt like if I turned my head I changed lanes.:eek: It's all good now. :)
  5. Deuced Up!
    Deuced Up!
    Here you go boys...a little of both!
  6. Nostrebor
    Nostrebor
    Is that rack NOS or aftermarket? It's hard to tell from the pic.:confused:
  7. Dick Stevens
    Dick Stevens
    I like to think it's NOS, I'm not a fan of silicone. :rolleyes:
  8. AVater
    AVater
    1. Connecticut HAMB'ers
    Ok. How are the headlights?
  9. ned5049
    ned5049
    Yah. It makes for fisheyes !!!
    Dick Stevens likes this.
  10. dan c
    dan c
  11. blowby
    blowby
    from Nicasio Ca
    Subscribed!
  12. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    Is it just me or is the obvious answer to use the matching ford pump- it can't be that hard to adapt
    and it would be correct for the rack.
  13. FIDDLER
    FIDDLER
    from VIRGINIA
    I HAVE ALWAYS WONDERED ABOUT TOO ,WHY NOT USE THE MATCHING PUMP? MAYBE THERE IS AN ANSWER THAT IS NOT OBVIOUS
  14. patterg2003 likes this.
  15. adapting may have been the answer before the engine went in the car, but now............
    not likely, don't want to scratch the paint.
    I'll go with the valve... thanks, Joe
  16. I'm going with the valve from Speedway. Thank you all, and I would like to thank the NOS MM2 girl also.....Joe
  17. Getting old is not the problem.... It's staying old!!
  18. xpletiv
    xpletiv
    from chiburbs
    She's alittle of both.
    Don't ask.:eek:
