Sheetmetal Guys:I need advise/help
Discussion in 'The Hokey Ass Message Board' started by SPDJNKY, Dec 29, 2011.
  1. This might seem like an easy fix but it's been fighting me so far. I'm relatively new at sheetmetal work so go easy. haha
    I have about five dents in the upper crown/edge of my firewall. They are deep and only about as round as a nickel. I tried to use a stud gun on them to pull them out but their not budging. I assume because the strength of the metal in the curve. I was going to try hammer n dolly them but it is a sharp curve on the back side which non of my dollies will fit in. The cab and firewall are welded to the frame because of the cage so I can't just remove the firewall. My thought was to go buy one of the dollies that is as round as a quarter and see if that will fit up in there or?
    My wise ass friends said to just mud over them but that would be too easy. :rolleyes:
    Any thoughts?
  2. SlmLrd
    SlmLrd
    from DAGO
    I am by no means a "sheet metal guy" but if what Im seeing is right, you need a hammer on the inside, not a dolly. Tap it with your hammer and push the dent out. form with your dolly and you're good.
  3. Couple taps with a ball peen hammer, not real fancy but it will work.
  4. squirrel
    If you want to get fancy, take a piece of 1/4" x 1" steel strap, about a foot long. round one end with a grinder then put it on the dent from the bottom and carefully whack it with a hammer, move it around as you work the dent out.
  5. Had that idea as well! Or make a T dolly like Ron Fournier shows in his book. Can you still GET his book? I bought mine darn near 30 years ago!!!!!!!!!
  6. 49worktruck
    49worktruck
    On the same plane as squirrel, try a pipe nipple of the same radius and weld a tab on to hammer.
  7. English Chop
    English Chop
    Attack them from behind, a little heat probably wouldn't hurt either.
  8. Rusty O'Toole
    Rusty O'Toole
    Fill them with plastic filler. Do it right and it will last forever. If you want to get fancy there are metal body fillers.
  9. These dents should be repaired cold . The metal isnt streched so no need to heat.
    Brian whats the rear access to the dents like ? Squirrel and TMan are on the right track , its just what access is from behind. As far as dollies go , I'm partial to redheads. Opps lost track . The dolly needed should be slightly smaller in radius than the crown of the metal where the dent is located . You actually dont want to do much hammer on dolly work. Hammer off dolly will be preferable. If you have good access to the rear of the panel you can just use a arced and rounded flat edge to tap the dent out from behind . Dont be afraid to hit it a little harder. You will need to equall the force than caused the dent to remove it . Repair of a dent like this is fairly straightforward.
  10. 49ratfink
    49ratfink
    no need for a dolly. I'd go over to my metal stash and get a piece of round rod of a proper length in a diameter that matches the dent and round off one end with my grinder. then I'd place it behind the dent and smack the other end with a hammer until it was gone. doesn't look like there is much hammer access behind it.
    easy squeezy
  11. 49ratfink
    49ratfink
    there is no need for any filler in a small dent like that. by the time you got your can of mud opened and mixed I'd be done fixing it right.:eek:
  12. Heo2
    Heo2
    Yes thats the right way or take a ballpen hammer and
    whak it with another hammer more control that way
    than whacking with the ballpen directly
  13. Thanks everyone! I was over thinking this one after hearing the suggestions. I will take a whack at it tonight. I'm going to try using a piece of schedule 40 nipple from the plumbing bin. If I have to I'll weld a piece of flat stock to it like the t that was suggested.
    I can get to back side of the firewall with some bending and sucking in my gut :D
    I'll report back.
    Thanks again!
  14. The hammer on the back of the ballpen hammer sounds good too because I have bad aim. Lol
    The depth of the dent had me confused I guess.
  15. Heo2
    Heo2
    I have several ballpens with various radius
    grinded to them im a litlle crosseyed to *S*
  16. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Another method to bump this type of dent out, given you haven't got a dolly or spoon would be with a piece of wood say,2''x2'' X12''. Round off one end with a grinder to match the shape of the inner panel, and with a 3# hammer strike the other end with soft to medium hits. Bump it, study the result & bump it again as necessary. Using this method will result in less of a chance of you stretching the panel vs. a metal to metal hit. Any small areas that remain low can be raised with a ball pien, hammer on hammer, or a small punch/awl. Little or no filler should be necessary to repair this dent.
    " Life ain't no Disney movie "
  17. 91bluecamaro
    91bluecamaro
    Fill it with lead...
  18. MP&C
    MP&C
    A broken broom or shovel handle cut to about a foot long, keep the rounded end and tap it with a dead blow.
  19. Heo2
    Heo2
    wery small chanse to stretch the metall
    in this place the firewall is so thick and in
    a radius like that wood is probably to soft
  20. tinmann
    tinmann
    As others have said, make a tool. I have a rack of purpose-built tools. They always seem to be handy for something new too.
  21. First off, thanks for all the advice. You guy's rock!
    I used a few different tools to get these dents out. I got to the back side and used a combination of two ball pen hammers, a 3/4" schedule 40 plumbing pipe, and the back end of a screw driver. I am happy with the results. There are a couple real shallow spots on a couple of them but I can live with 1/16":D. Here's a couple pics of the half dozen I repaired.
  22. Flop
    Flop
    nice! file em out and you should be on your way!!!
  23. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    Sorry, i know im late... but a stud welder would have worked great and taken little time...
  24. squirrel
    uh....maybe he tried that already?
  25. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    oops... i should def read the whole thing before i respond... my bad. I use my stud welder to pull out dents like those all the time...
  26. squirrel
    Might be his slide hammer is to wimpy....
  27. Mark Fox
    Mark Fox
    A job well done. This web site is magic.
