So as I'm stripping all my body panels down to bare metal to get ready to paint I'm finding a few sections that have intereting patterns in the surface of the metal which I can only assume are from some type of metal straightening technique. I've never seen these kinds of patterns in sheet metal before and was wondering if anyone knows exactly how they were put there. On the bright side, it's better than finding body filler.
Usually you'll find stuff like that under old lead work. Did you remove lead? How old is the car? Factory bodywork (lead) is usually easy to spot. Most often it's encountered covering lapped, welded seams or around door and window openings. Anyway, it's better than rust!
a vixen has large teeth so to speak afaulk for cutting through lead and steel . those are the tell tale marks of a vixen .
Indispensable tool! I'd say old repair. Factory would have done a little better finish. I use the shit out of mine! You can make ugly disappear!
So what is the exact technique to use the file to shape metal? It appears like it's just a bunch of random grooves in it, and why such random patterns on my fender? Here's another angle:
The file is drug or pushed (at a slight angle) across the surface and marks the metal. That helps you know where it needs to be bumped up / knocked down. Once you get it level enough you can shave the surface to level. Looks like some pretty deep grinding marks on your fender. 24 grit was common back then.
I did not encounter any signs of lead. I basically just used aircraft paint stripper and a wire wheel on my drill to strip all my body panels.
Like Tinbender said, Vixen files make ugly disappear! That's a good thing. They can also make ugly reappear in the form of REALLY thin sheet metal. It's a great tool in the arsenal, just don't go too crazy. As far as your pickup is concerned, just D/A the scratched panels working your way up to 120. Whatever is left will be easily filled with mud,primer,paint...
