Serpentine for 371 Olds
Discussion in 'The Hokey Ass Message Board' started by oldspert, Dec 16, 2011.
  1. oldspert
    oldspert
    from Texas
    Anyone know of source for a serpentine belt and pullys for a 57 371 Olds engine?
  2. How do you even run it so it runs the water pump the right way? Tensioner? You'd probably have to buy the pullys and sort it out yourself, the odds are against anyone making a kit. As for the belt, you'd have to figure out how to run it, then run a string around to measure how long.
  3. drag_punk
    drag_punk
    Why, this makes no sense, besides that you'll never find a kit to do this. It would be hideous.
  4. chubbie
    chubbie
  5. GOATROPER02
    GOATROPER02
    from OHIO
    Custom pieces only
    And I have to say, I don't think it would fit with the look of a vintage powerplant
    Tony
  6. mgtstumpy
    mgtstumpy
    I've never seen a reverse rotation water pump for an Olds, but plenty of Chevs
  7. nexxussian
    nexxussian
    You would likely have to make iyour own reverse rotation water pump, adapt another pump to it, or run the serpentine belts like V belts, which defeats the purpose.
    I too would like to know why you want to do this
  8. oldspert
    oldspert
    from Texas
    Not for me. A person I know just bought a 57 and was inquireing. I didn't like it either, but it's his car.
  9. bobwop
    bobwop
    if he wants a serp belt system, he may have inclination to add air conditioning.
    but in reality, he may as well pull the 371 and sell it to somebody that appreciates it and just stick a belly-button sbc under the hood.
  10. oldspert
    oldspert
    from Texas
    It already has factory air. I threatened to cut off his nuts if he puts a chevy engine in it.
  11. bobwop
    bobwop
    you should cut them off if wishes to install a serp belt system
  12. There is a one word answer: Why?
