Technical Seriously: muffler grease ?
Discussion in 'The Hokey Ass Message Board' started by Fenders, Aug 25, 2014.
  1. Fenders
    Fenders
    Seems I'm always changing, swapping or replacing my mufflers... and the slip joins rust up pretty quickly... anyone ever put grease on the muffler / pipe slip joints to make them easier to remove? What kind?
    And no, the muffler bearings don't need grease .....
  2. Sounds like you need to use bolt on flanges?
  3. rusty rocket
    rusty rocket
    What about a good quality anti seize?
    J&JHotrods likes this.
  4. squirrel
    Anti seize would be what I'd try. But I also know that if you get the clamp tight enough so it won't leak, then the pipes will be deformed so much that it won't slip off.
    Bolt flanges are what I use on any exhaust system I plan to take apart.
  5. Bolt together flange is po-po, v-band clamps are quick, don't leak and only one bolt to undo.
  6. squirrel
    I was going to use V band clamps, but couldn't find them in the 1966 Honest Charlie's catalog.
    slammed likes this.
  7. jbrittonjr
    jbrittonjr
    I use Permatex anti-seize on most all exhaust pieces.
    slammed likes this.
  8. RichFox
    RichFox
    squirrel Member
    New
    You needed to look in an aviation Illustrated Parts Catalog. Or a real good surplus store. Or work for an airline. In '66 I was working for an airline.
  9. King ford
    King ford
    from 08302
    When I was wasting my youth working on stock cars some tracks required mufflers some really quiet mufflers some none at all.....we usedneverseeze and stainless strap clamps(about three inches wide...napa has em)....slid on and off like having sex!
  10. Walker used to have exhaust pipe sealer in a tube. Black gooey stuff that sealed and prevented rust fusion.
  11. slammed
    slammed
    This answer is very clear, and was available to the general public at large.
  12. seb fontana
    seb fontana
    from ct
    67' catalog has them..........
  13. High Temp Anti-sieze work very well.
  14. jack_pine
    jack_pine
    from Motor City
    What is "po-po" ?
  15. funk 49
    funk 49
    Cat. copper anti sieze will do the trick.
  16. use "copper coat" antiseize
  17. The anti-sieze will work best if you clean the pipes first with some good prop-wash. :confused:
  18. Fenders
    Fenders
    Excellent ideas guys -- thanks !!
  19. blue 49
    blue 49
    from Iowa
    For a while, I used 283 rods for hangers for my 2" tailpipes. I did have tailpipe bearings.
    Blue
  20. sunbeam
    sunbeam
    The walker sealer would turn to carbon and seal the voids in the joint
  21. Blue One
    Blue One
    from Alberta
    You have personal experience with the effectiveness of V band clamps ? I'm going to start fabbing my exhaust system soon and have a box full of V band clamps.
    I want to be able to take the exhaust apart in sections to ceramic coat the whole works.
  22. Ned Ludd
    Ned Ludd
    It's an expression of doubt or disappointment used by elderly Greek women. There is, however, nothing on the profile page to suggest that Rodhotz is an elderly Greek woman :)
  23. theHIGHLANDER
    theHIGHLANDER
    I did a 37 Packard 12 with the original and unmolested drivetrain. It had the 2 bolt clamps that are very similar (if not the same) as what's used on today's cars. 2 bolts that pinch a tube-shaped clamp with a small ridge around the center.
  24. Jeeze mines all welded solid. :(
    -Pat
  25. They work nice.
    The band clamps also do a nice job, the come in over lap and butt. If I were building something that needed to come apart frequently, or modular I'd use either the v band or butt style clamps. If it were v band I'd upgrade the bolts too.
  26. gimpyshotrods
    gimpyshotrods
    I have worked on turbocharged cars, running absurd boost (3-4 bar). If a v-band clamp will seal that, at that temperature, it will hold just fine in any lesser application.
  27. J&JHotrods
    J&JHotrods
    If you just have to run slip fit pipes my vote is for copper anti-seize as well.
  28. remember the Y block fords? they had the crossover pipe up front and no clamp, did they use any antiseeze on that?
  29. Fenders
    Fenders
    Anti-seize it is!
  30. Yep use them all the time, on a few turbo diesels we are running over 100# boost and no problem holding, come time to disconnect just undo the bolt and that is it.
