September banger meet
Discussion in 'The Hokey Ass Message Board' started by BHT8BALL, Sep 3, 2011.
  1. BHT8BALL
    BHT8BALL
    Hope this isn't too late for the new thread. Here's pictures in progress of our new 2-piece cylinder head for pop-up domed pistons. The pieces will be joined by aluminum dip-brazing, re heat-treated and then final machining. With std. bore and our design piston the comp. ratio will be 9:1, with 4.0 bore this increases to 9.5. Front surface of head is designed to allow either stock A pattern or 21 stud V8 pump. Provision is made for the stock dist. but it will not be drilled thru as these heads were intended to be used with our front cover with the dist. mount. With our skills & the small quantity to be made, the cost of a (good) casting would be a lot more in time & $$$$ so we decided on fabricating them. Certainly no purist would be caught with one!
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.billsbangers.com
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/s...=470853&page=6
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tu...e-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/s...61#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/s...d.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculatorfin.jsp
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?...icdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/T...e-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/s...470853&page=10
    Maybe these links should be posted early in each months meeting.
    If anyone knows of more, please post them.
    __________________
    " I've tried nothing ...and I'm all out of ideas."
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/s...d.php?t=256226
    out plowing likes this.
  2. RussTee
    RussTee
    Pat right up to your usual standard great work these will look great with your front cover .I think this is the new tradition hotrodding does not stand still this is new work done in traditional style it would also be a shame to polish your work the finish is that good great to see someone push the boat out this is the new old the next step in traditional hotrodding well done
  3. Nailhead dodge roadster
    from Cheney Wa
  4. 38FLATTIE
    38FLATTIE
    from Colorado
    That looks to be very well thought out and machined!
    Very nice!
  5. RussTee
    RussTee
    Sept Banger Meet looks like this is it?
  6. RussTee
    RussTee
    Look at earlier posts by BHT8BALL and be amazed love the workmanship
  7. I don't have anything to buy or sell but i think that is a nice piece of work. What are you going to use for intake valves? What diameter? I'm considering 1 7/8" next time I pull the engine down. Probably open the seat area up to 1 5/8". I will have to go with a CI Winfield "Crows Foot" to get clearance.
  8. Jimmy2car
    Jimmy2car
    from No. Cal
    Just curious, what is the reason for the new head? More power? What?
    Thanks
  9. BCCHOPIT
    BCCHOPIT
    thanks for the barger porn....WOW:D:D:D
  10. noboD
    noboD
    Good looking way to start the month. How about some more details?
  11. "Certainly no purist would be caught with one!"
    This looks very pure to me 8 Ball ! You do amazing stuff with that unobtainium.:)
    Ron
    p.s. purists as in antiquers, trad rodders, new rodders ,street rodders ? I think Ricky said it best in "The Garden Party"....Can't please evryone so you got to please yourself.... Keep up the great work .
  12. BCCHOPIT
    BCCHOPIT
    The only thing new to me is my new
    Tach. Now to find the time to put it in
  13. Bluto
    Bluto
    I got a huge box-0-them at a truck meet. Not one I could use but they look nice :)
  14. Gaters
    Gaters
    I am checkin in to keep tabs on you guys.
  15. Bluto
    Bluto
    Ron did you get the carbs sortted out?
  16. The37Kid
    The37Kid
    Fastest Bugatti GP cat at Lime Rock today, it is 1932 Ford 4Banger powered. The Conversion was made back in 1938.
  17. Bluto
    Bluto
    Bob It's good indeed to see you up and running :):)
  18. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    just took my 30 coupe, stock banger on a 119 mile run up to get huckleberrys today. Total elevation of 6000 feet.
    what fun!
    crappy pic.
  19. drove the side roads up to the cheaters show last weekend.
    round trip was 107 miles
    average 16 mpg at 50 mph and only one quart of oil
    and some sunburn
    loven it
    tk
  20. Bluto; I did order a pair of Grose Jets for the Zeniths but they haven't arrived yet. I have been working most of the week (I check drawings for engineering offices on an "as needed" basis) and have been trying to catch up on a bunch of neglected issues around the house and on the "every day":( cars. I am going out to the shop this afternoon however, to check a few items off your list. Thanks again for your help and concern and I will keep you up to date with my findings.
    Hope you are feeling better Jim:)
    Ron
  21. Bluto
    Bluto
    Hey I wasn't pushing just looking for some good news.
  22. I knew that Jim and I'm sorry if you thought that I was being sarcastic. I wouldn't be that way , I was just telling you what was up as you were kind enough to offer your help when I asked for it.
    Ron
  23. BHT8BALL
    BHT8BALL
    RussTee, I don't know the proper format for starting a thread but decided to just get wet! Welcome any suggestions, Pat
  24. BHT8BALL
    BHT8BALL
    Bill & others, thanks for your appreciation for all the hard work, I am now learning from my son & couldn't have done this without his help. Son Brian has a '29 rpu in progress, thru helping me with banger projects he is now considering not using a V8 flathead and installing a banger! ( Applause now please! ) Hope we can keep the bangers alive a few more generations. Bill, the finished chamber will allow a 1 7/8 intake & 1.7 exhaust valve. There is also room for an oversize cam with lift up to .500, this head will accept the Best 509C head gasket. Pat
  25. BHT8BALL
    BHT8BALL
    The intent is that with higher compression without restricting the transfer passage will translate into more hp. Next project is to make my Schenk dyno opperational and verify or demolish my hopes, Pat
  26. V4F
    V4F
    from middle ca.
    if the new head doesnt work for you , i have a home for it ! ................. steve
    damn that would freak peeps out if it were on my coupe !
  27. Thank you!
  28. RussTee
    RussTee
    I am not sure either Pat but we better point out that they usually post Banger helpful hints at the start anyone new please read the helpful hints at the start of last months thread.
    Hey Pat be a devil and post a picture of your front plate alongside that head just so the banger fans can see the 'New Traditional' that I am talking about.
  29. BHT8BALL
    BHT8BALL
    I'll go back and read the instructions tomorrow, maybe I can copy & paste them in. Anyway here's a mockup for a Bonneville engine with Hilborn pump & Scintilla mag. There are 3 positions available to clock the pump, I didn't show the damper because there was a burr on the crank keeping the hub from going on. I'm including a picture of Lee Hammock's track roadster to show the damper. Pat [my pictures were rejected 3 times so i'll try a different approach]
