I'm trying to seperate the trans from the flathead.The trans spins freely. Any suggestions? street rods are driven by Chevy, but hot rods are powered by Ford!
The starter is off. I tried using a pry bar, very lightly, while pushing in the clutch and no luck. street rods are driven by Chevy, but hot rods are powered by Ford!
Try whacking the case with a rubber or wooden mallet. Something is rusted together. Tread lightly for you don't want to hit it so hard that you knock a hole in the case, but a little jarring should free up those rusted splines.
Squirt some god penetrating oil like T/f & acetone mixed 50-50 on the splines for a couple days. Should work Butch
I will give that a shot and see what happens. street rods are driven by Chevy, but hot rods are powered by Ford!
Pull the throw out inspection cover off and hit it really good with some penatrant .. Let it sit .. Worst i ever encountered was a siezed 324 olds and 39 trans I had to cut the block and remove all the clutch bolts from the flywheel.. Then I had to cut the disc off the imput shaft .. If your motor spins you can probably pull the pan and do it that way..
Now that the trans is separated from the flathead, can I adapt it to my banger motor? street rods are driven by Chevy, but hot rods are powered by Ford!
I will check it out. Can you give any tips on the do's and do not's? street rods are driven by Chevy, but hot rods are powered by Ford!
I have bought some brake parts from Clings and he is very helpful. You might give him a call . Dennis Cling. (480) 777 - 1202 John
I have the adapter and some of his brake stuff. Great product. Posted using the Full Custom H.A.M.B. App!
I have to save up the doe. It's $475.00 through clings and Snyder's. street rods are driven by Chevy, but hot rods are powered by Ford!
