Technical Sectioning a 1949 cadillac
Discussion in 'Traditional Customs' started by jub, Jun 16, 2009.
  1. Rikster
    Rikster
    I had a bit of time last night when I could not sleep and came up with this...
    Not easy to make probably... Window trim comes from a Sedanette, but the four door trim could probably also made to work... with a slightly different shape.
    Body on both was not sectioned... but I did extend the rear fenders for a longer look.
    And this version was chopped a bit more to get better proportions.
  2. Very cool - particularly the delivery.
    I agree that the sectioning is not necessary.
  3. Not sectioned, but a friend of mine did the chop on this one, his first chop too.
  4. 51 MERC-CT
    51 MERC-CT
    And maybe a little sectioning:):D[​IMG]
  5. jub
    jub
    from York, Pa
    Well you guys are just awesome. Thanks for the insperation, i will post pics as I go. Once again thanks for the help with the pics.
  6. jonzcustomshop
    jonzcustomshop
    A spot to section at that people forget about is the beltline, that is how the barris boys did a 54 caddy convertible...
    how would the delivery look with the beltline sectioned out, and the hood pancaked?
  7. teisco
    teisco
    Just watched Monster Garage last night and they sectioned the rear of a old cad.
  8. jonzcustomshop
    jonzcustomshop
    here is a rough photo chop using rikster's delivery photo...
    beltline cut out, hood pancaked:
  9. Rikster
    Rikster
    Took a little out of the belt line... not too much. And did some reshaping here and there to get it all flow a bit better....
  10. jonzcustomshop
    jonzcustomshop
    that just looks evil!
    would be a ton of work... but worth it in the end.
  11. koolkemp
    koolkemp
    WOW !! Stunning, the ultimate classy sedan delivery!!!!!!!!!!
  12. twochops
    twochops
    Rikster-great job of photoshopping.Black Caddy wagons always
    make me think of a Funeral Home, maybe a different color or putting
    on a 1948 Tucker flattop roof on it would be nice.
    TwoChops
  13. Big Somoan
    Big Somoan
    I like the wagon version...
  14. ProEnfo
    ProEnfo
    from Motown
    That's evil looking... great PS Rik
    CC
  15. Rikster
    Rikster
    A few quick colors....
  16. resqd37Zep
    resqd37Zep
    from Nor Cal
    Stop it already! You're killing me. Now I want one. I'm digging the green one.
  17. If you do end up using that ambulance as a donor be aware most of those bodies are steel over wood, like 30s GM cars, you'll have to rebuild that part most likely to chop it.
    If you go delivery you might be able to use a 49-52 delivery parts car for the top, there's enough of them out there.
  18. jub
    jub
    from York, Pa
    I like the green one too that is acually the color I will end up painting it one day. I want to do a green body like a metallic and a off white top.
  19. Double Caddy
    Double Caddy
    from virginia
    you guys are making me rethink my 52.:D
  20. Hammer76
    Hammer76
    from MILANO
    you have other photos of this job?
    thanks
  21. 50Fraud
    50Fraud
    There was a sectioned Coupe de Ville, about a '51 model, done in the early '50s. I don't remember which body shop did it, but the cut was taken above the fender line and it looked quite good. It was a magazine feature car, but I don't recall whether it was Hop Up or another one.
    The car was painted black, and I saw it parked on the street in Santa Monica within a year or two after it was built. Rik, do you know the car I'm talking about?
  22. metalman
    metalman
    5 year old thread, wonder what ever came of the OP's project?
    FWIW I do have a pic of the Caddy I did with the tapered chop and section, can't believe it's been 20 years ago.
    Another on I did a straight chop and section, it's an Olds 98 but same body as the Cad. These are how it left my shop, it's since has had the suspension done to sit it down proper and is close to paint I hear.
  23. Salty
    Salty
    from Florida
    Lol.....I was just thinking about you as I was reading this thread....I hadn't looked at the dates but I was going to point the op in your general direction due to the two cars you just posted up....
    Fortunatly a 49 Chevy AD section does not entail the same intestinal fortitude that yours do!
  24. Hammer76
    Hammer76
    from MILANO
    no sorry do not know this car.
    my idea was to cut the lower part of the body just as was done in the photo on page 1
  25. Hammer76
    Hammer76
    from MILANO
    good cut
    you cut off the bottom as I'd like to do
    you have other photo?
  26. metalman
    metalman
    I have a few other pics, what are you looking for specifically? Not sure what you mean by cut off at the bottom. I went right thru the middle except for the door skin itself, that I took off, cut the bottom off and put it back on the frame.
  27. Hammer76
    Hammer76
    from MILANO
    [​IMG]I found a video where it is cut centrally along the length of the car, I would do it like in this picture, where it is shortened from the bottom, where the body is more resistant, even some of the upright body then goes tgliato higher
  28. Hammer76
    Hammer76
    from MILANO
    for me to understand better
    watch the video, a great job, bad welds and sheet metal worked a little bad but it was a great job
    cut in the middle where the sheet is much more delicate above all the doors, instead cutting the bottom is more resistant
    I hope to explain well
    http://www.youtube.com/watch?v=-qbyAvozGMk
  29. jfrolka
    jfrolka
    bitchin caddy
  30. Hammer76
    Hammer76
    from MILANO
    sorry
