Customs Seating in a Caddy
Discussion in 'The Hokey Ass Message Board' started by stubbsrodandcustom, Feb 14, 2025.
  1. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Need to pick some brains, I just bought a 51 2dr Cadillac. I fell in love with the style, but when trying to sit in it, realized that its not tall or big boy friendly. seat slider is all the way back, and the rear side panels prohibit it from going back much further anyways. The last picture shows the seat bottom just laying in there, but even getting it slid into its right spot its too high.
    Anyone else have any recommendations here other than getting a complete different seat from a totally different vehicle?
    I sit too tall in the car, my eyesight is at the top of the windshield, and cant really even do the pedals.
  2. alanp561
    alanp561
    Those aren't the original seats, right? I'm 6' 2" and I had all kinds of room in my '55 Cad 2 door HT, knee clearance and steering wheel clearance. It looks like whoever did the upholstery went a little overboard with the foam.
  3. stuart in mn
    stuart in mn
    In the last picture the seat looks awfully close to the dashboard. There should be more room , make sure the seat adjusters aren't rusted or otherwise have something preventing them from going back all the way.
  4. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    I agree that those don’t look like the right seats. You should have all kinds of room in there. That front seat looks way too close to the dash.
    hrm2k, Johnny Gee, alanp561 and 2 others like this.
  5. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I agree the seats look overstuffed like a fat kids halloween haul bag. I know the seat bottom isn’t completely in. It’s fighting going in and I need another set of hands to get it in. The seats bolt in stock location and all the frames and springs look just like the seat that was removed other than the thick back. But I’m compressing the bottom seat springs a lot cause I’m a big boy. Here are a few pics with tape measure. IMG_8010.jpeg IMG_8011.jpeg IMG_8012.jpeg IMG_8013.jpeg
    guthriesmith likes this.
  6. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    For reference this was my Buick I just sold. Tons of room.
  7. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Not sure how many,need to tell you,those seat are not for that car ?
    Hunt up the real seats that came in it,an redo as needed. Cadys from that far back are cool,ya got a cool car.:D:cool:
  8. BJR
    BJR
    That seat back is way too thick and is pushing your butt forward. Notice how short the bottom cushion looks and you say the bottom is not all the way in yet.
    stubbsrodandcustom likes this.
  9. Oneball
    Oneball
    Stock seat in a 4 door, looks just like yours is over stuffed to me.
    alanp561 and stubbsrodandcustom like this.
  10. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Vert has the same seat it seems.
  11. alanp561
    alanp561
    In your first post, you mentioned that the rear side panels kept the seat from going farther back. Is there any side clearance at all? It would probably benefit you to take the seat out of the car so that you can more easily get the seat bottom into place. I assume that you intend to repair the floor pan anyway, and it would be easier to do that with the seat out.
  12. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Hmm…I would have sworn those were the wrong seats. Hard to believe a Caddy would have so much less room than the other early 50’s GM cars though. :confused:
    stubbsrodandcustom and alanp561 like this.
  13. TCTND
    TCTND
    Looks like the right seat, but not properly assembled. The bottom cushion should be lower and further back. Take it apart and see what's going on.
  14. southerncad
    southerncad
    FWIW, and I know you didn't want to hear this, but in my '49 (see Avatar) I ended up using '97 Eldorado front seats, yup, not trad, but fit, and comfy.
  15. ekimneirbo
    ekimneirbo
    I'd start by removing the cover from the seat without damaging it......and check if some padding can be removed. Those old seats usually had a lot of open space under them that you might be able to lower the seat some.
    If the rear side bolsters that are keeping the seat from moving any further back don't have too much interference, while the seat is apart, you might check to see if you could just narrow the seat frame and seat back frames an inch or so and then have the upholstery resewn to fit. It might allow clearance to move back farther and be unnoticeable. The upholsterer could possibly modify the seat backs on the inside center area and keep the upholstery you have already.
  16. partsdawg
    partsdawg
    from Minnesota
    That seat looks like how I feel after leaving a all you can eat buffet. Way overstuffed.
  17. BJR
    BJR
    My chopped 49 Buick has a stock front seat in it. After the chop I was looking through the shaded part of the top of the windshield. I cut down the seat sliders and cut down the seat frame that the cushion fit into, so now my seat is almost on the floor. It lowered it enough so now I can see through the clear part of my windshield. I also moved the tracks back 2" as it helped with leg room and vision through the windshield.
  18. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I’m blessed with another seat so I may try to hack on that a bit since it’s almost completely stripped down. Appreciate the insight.
    I think the Buicks were taller In the door openings.
  19. BJR
    BJR
    In 49 Buick used the same bodies as the Cad from the cowl back. I believe it's the same in the early 50's.
